Setting up a WS.6 to handle?
What are you guys doing to these cars to get them to handle better? I don't know anything about 4th gen suspensions really, I'm a first gen guy when it comes to this stuff. Since this is going to be a daily driver(when i get it), and the '68 is the hardcore road racer, I'm not going to go too hardcore, and I won't be doing most of thist stuff for a while. I'd like to pull about 1G on the pad when all is said and done. Obviously stiffer shocks and springs(unless I got to c/o's), and some bigger front and rear bars(preferred manufacturers?). Does anyone make 4 wheel c/o kits for these cars? Who makes "the best" SFCs. Any preferred manufacturer on Tubular UCA/LCA for handling? I get the impression that a lot of them are more drag racing oriented. I probably won't do any of this stuff until the Camaro is done, but I just want to learn more about the 4th gen suspension setups.
Can anyone turn me on to some other suspension companies for 4th gens?
All I really know if of is:
Global West
Hotchkis
BMR
All I really know of
Thanks,
Ralph
They have lots of RR goodies for your camaro. From what I've read, their c/o kit is considered topnotch but pricey (I guess you get what you pay for).
Sam Strano is another you can try www.stranoparts.com
I got my front swaybar from him (35mm hollow) and it's an awesome piece. He can help you with your setup (nice guy).
Another good website for f-body RR info is www.frrax.com
(I'm only going to give this away once!)
SLP SFC's and a roll cage for stiffness
Koni's SA's on all four
Hotchkiss 36 mm front bar, 1LE 21 mm rear
Ground Control CO's 500 lb/in front 150 lb/in rear
Aluminum rod end control arms front and rear
Aluminum rod end pandard
Lowered 2 inches with Relocation brackets
Wheel alignment with -2.0 camber 3/32 toe out
16 inch forged aluminum wheels 10 to 11 inches wide on all four
adjustable torque arm
That pretty much does it. If you do all that, I promise you will be pulling over 1g on the skidpad!
Edit: Some good tires would help a lot also, but I'm not sure which are best for the street. A lot of guys like Nitto 555RII's though.
With my combo, drag racing is out of the question. Unless I want to do the first 100yards in tire smoke, its not even worth going. But when it comes to road course work
Its a little rough on the street but bearable IMHO. Most people that have ridden in the car complain about thier kidneys hurting but oh well, to bad for them. Trending Topics
With my combo, drag racing is out of the question. Unless I want to do the first 100yards in tire smoke, its not even worth going. But when it comes to road course work Its a little rough on the street but bearable IMHO. Most people that have ridden in the car complain about thier kidneys hurting but oh well, to bad for them.
Good to hear, LG was what I was leaning towards. I won't spend that much on this car, as it will be my daily driver. The ride needs to be semi decent for that reason as well.
I'm building a '68 G-machine that is primarily built for road racing, and open road racing. I'm saving the super stiff ride, and ultra hardcore suspension for that car, I'm hoping to pull 1G on the pad with it. (DSE tubular UCA/LCA along with c/o kit (relocates mounting points and further alters geo, than just the UCA), DSE SFCs, and a custom 3-link built for road racing, 12pt cage, 1" front bar, custom rear bar, etc, etc, etc.).
I'd just like this car to handle nicely, nothing ultra hardcore, yet atleast) I will take it to the strip and have some fun with it, I'd like to be able to hook decently (2.0ish 60ft). Considering that the Camaro will not hook for anything (335/30/18s) and I'll have to muscle the 1/4 out on all top end (650rwhp), I'd like this car to make up for that somewhat.
P.S. I see you run SSC. What tech class are you running in, the 150? I'd like to run the Camaro in the 180 class eventually, but seeing as how I'd have to run the 130? class first, then work my way up, it may take a few years, and I'm not sure where I'd be car wise at that point.
Running in an ORR event is a WHOLE different monster than any other form of racing. If you plan on running in the faster classes down the road, be prepared to do some things to the car that you might not have expected.
I've heard that getting tech'd into the upper speed classes is crazy. The Camaro will have a lot of safety provisions, it's basically going to be a race car with plates (except for the SMALL stereo). I doubt I'll tech for the unlimited class, infact I'm almost sure I won't. The 180 is a slight possibility, but might require some more non-street friendly mods.
Remember that a car that can pull 1G in a corner can still be a very bad handling car. You can throw slicks on a stock '63 Plymouth Valiant and pull 1G but it's still a suicide ride at high speeds
Here's my major suspension mods
Prokit springs
Koni DA front shocks ( SA would do nicely too for less $$ )
Bilstein HD's on the rear
LG rod ended LCA's and PHB with relocation brackets
There's other smaller things I've done, and other things I'm going to do, but the above parts with a decent performance oriented alignment will go a long ways to curing the ills of a stock suspended 4th gen while not killing the budget
I hear you about a death trap at high speeds. There is alot of engineering and design behind the Camaro to prevent just that. I'm going for the 1G on street tires (Michelin pilot sports). Hopefully I'll reach that mark, I've got a lot of racers that have raced these cars for a long time helping me, but who knows until I get some numbers, it's all just talk.
Thanks for the tips on the mods, I'll keep them in mind, they sound like what i was thinking of, good shocks/springs and some lcas.
SLP told me that since the rest of the car was still stock, with those (and they were talking about just bolting the SFCs) I would be unable to harm the chassis in any way short of hitting something.
As time goes on, money becomes available, and my skill level increases, I do plan to continue modifying it with handling and that kind of racing (RR, Time Attack, AutoX, etc) in mind.
How much difference does a cage actually make? To be honest, I really do not want a cage in my car - it's damned ugly, expensive, a hassle to get installed, and PITA to work around afterward. But, I'd rather have my car last forever more than I'd rather avoid those issues.
Am I in danger of twisting or fatigueing the chassis by thrashing it around corners if I don't have a cage?
I have Eibach prokit, koni adjustables, hotchkis stb & sfc's, RK sport anti roll bars, powerslots, and only 16's so far, and it's not too rough on all soft, and handles superb!!!
I mainly have my car setup for drag racing....solid LCAs & a BIG rear sway bar...but with some tweaking of shocks & such I'm going out with NataSS & Racehead next year to do some ORR. I will likely stay in the beginner class (120-130) but that still means I get to roll at 140-150mph. And take turns at speed! Anyway, SFCs, cages & springs do a lot for these cars. You can get there pretty easily. These cars can do it all.....
PS I had mine doing 145 (pre Moser) & it felt fine. The WS6 hoods break apart @ 190!
WAHUSKER,
I hope to see ya at some events as well, I probably will only make it out to 1 ORR event a year, they're all on the other side of the country! I'll hopefully be at a few open track days per year though, on the east coast.
