Pyrometer
Anyone have xp with dif ones? How about the good/bad between a manual one where you put the probe on the tire and a laser one?
Both are in the same price range ($100-$110).
The manual probes are flimsy, at least on mine. I'm surprised it didn't break a long time ago.
I use both....depending on which one gets there 1st, and then I take a back up with the other one <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
What brand do you use? I see a Reb-Co probe type and I use their air pressure gauge and like it. The laser one is Summit Racing brand, and they claim it is accurate to within 3%.
I only need one G2. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
As for testing the tire quickly after the run.. it'd prob be about a min, maybe two before I could get to the tires and test them after each run. And that is after driving slowly back to the grid and parking for the next run. Will this scew the results of either type of meter?
I don't think they'll let me jump right out and test tire temps directly after the run before parking for safety reasons.
BTW, right now this is for autox, but next year I'll be using it for rr too.
Ive used a rebco, and the regular lazer. I reccommend the rebco, and I think that they also sell the lazer type as well.
You cant go wrong with the Probe type <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Louis
http://toolsource.com:888/ost//produ...J74979AVJB7478
Seems to do an adequate job
They only offer a 1 year warranty, and both recently began acting flakey. The display would jump around to unusual readings even when it was on but not in use.
Make a sheet to record your changes too!
What I'm really interested in is a really cheap way to get my corner weights. I had read somewhere you can use something with bathroom scales. But, at almost 4000lbs, I don't know any bathroom scales which display up to 1000lbs, or wouldn't be damaged.
http://www.tgsi.com/scales.html
G2: Do you have any opinions on using this lever setup vs. the $1000-$6000 setups?
Aria was at the DC race, and Im sure that he can vouch for having a car setup properly. Did we have the scalepad setup then or not? I dont remember <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
By the way, have you guys decided what series to call home next season? Happy studying...
Aria
