ABS on the roadcourse
What role does ABS have on the roadcourse? Are you guys running with or without it? Pardon the novice question.
Anyone have experience with SJM, specifically the ABS delete? SouthFl.02.SS, I saw where you had ordered the kit... have you had a chance to install it yet? I did a search but didn't find many results with reviews on it.
I opened the box and saw all the brake lines and told myself "no way" (I had intended to do the install myself).
The instructions were very clear. The shop installer told me the kit was a little difficult to piece together, as he had to do some alteration to some fittings and some lines. I have no idea the extent of what he did, but I can definately tell you, I'm glad I did not install it.
Before the kit, the brake pedal would pulse (rear ABS sensors were not functioning properly) and the brakes were definately not hauling the car to a stop properly.
Post install, the brake pedal works smoothly. Braking is fluid and strong again.
What type of shop did you take the car for the work to be done? Some places may have a problem with removing ABS from a late model car around here. Lastly, how many hours labor did they charge ya for the install? You can PM or E-mail me with the info if you'd rather
Thanks!
Thanks!Trending Topics
