new, looking to autocross
Sam Strano is the guy you want to talk to PM or give him a call, he'll be happy to give you advice on what you need, as well as sell it to you (don't worry he won't just recommend a part just make a sale)
I see an F-bod being at home on a roadcourse. I see it being caged in on a tight autocross course. It's a matter of size, dimensions and weight. Sure, you can make it work, and work competitively, but I think, logic dictates that there are much better platforms out there to use as a baseline.
That said, if Fbod is the way to go, call Sam Strano. He'll point you in the right direction.
Shocks (konis)
Sway Bars (call Sam Strano)
Springs (Hotchkis)
Brakes (pads- HAWK HP Plus at the very least)
plus misc. suspension components. (LCA's, Tq Arm, Panhard rod)
chasis bracing (subframes if no roll cage).
Shocks (konis)
Springs (Hotchkis)
Don't throw parts at the car. Don't replace 3 different things at once. I say that because then you'll know how each part of the suspension affects your driving. Once you become a consistent driver, you will know what to tweak your setup for different courses/tracks.
You'll likely end up with new shocks and bars anyway, but your wallet will feel better about it when you can appreciate the difference
Call (don't write) Sam Strano @ 800-729-1831. I say don't write because he gets the best feel for your goals from a personal conversation.Learn on street tires. No need to build false confidence by going directly to R compounds.
I would recommend visiting www.frrax.com also, as it's a dedicated site for autocrossing and road racing your F-body.
