Dumb Question That Needs Answered
****(drivers school)****
1. front sway bar 35mm hollow (sam's bar)
2. rear bar 22mm(sam's bar)
3. front shocks (koni's or bilstiens valved by sam)
4. rear shocks( koni's or bilstiens)
5. front springs/ sam has a custom spring
6. rear spring
7.t2r diff (makes a huge d
8. 17x11 on all 4 corners
9. Alum flywheel
10. headers, engine upgrades.
And I'm not doing a k member for better handling, I'm doing it for more clearence. Right now everything is so tight it makes everything I do to the car not fun at all. And I'm also doing it to help balance the car back out after I install the cage. I'm going to try to make it to Road America with the NMFBA?? in the spring of next year to get some good insite on what I should be doing and what I'm doing right. Should be a good time.
But you are saying to get the konis first....that sucks LOL those things are expensive, but all of the good reviews I have read I know they are going to be worth it.
Thanks again guys, time for me to start looking at some more mods
Ive driven a stock RSX (non-S), sure it wasn't a type-S, but I got an overall idea of how the car is. The RSX had absolutely nothing on my car with Konis and otherwise stock suspension. Ignoring the power difference my car could hold so much more speed in turns, while being able to feel everything it was doing.
Konis should be the very first thing done to these cars, the difference is ridiculous.
I don't know that anyone does (not even Koni USA or True Choice) on the single/double adjustable street shocks.
Now of course they do for their alloy, threaded, coilover racing dampers.
The ONLY shocks that Sam has revalved (AFAIK) are the Bilstein HDs.
the Strano ESP setup is a no brainer multiple national championships. if you listen to what he says , your car will handle great . if your not fast after that
then look in the mirror.
But anyway above I was just saying basically its easier to convince the wife to spend $500 here and $200 here and $150 here than it is to say that I'm spending $850 on parts. I'll probably order the front struts, then in a couple weeks order the rears and install them. Then in another few weeks order the springs, and then a few weeks after get the sway bars. She doesn't mind me wasting money on my car as long as I don't do it in big amounts. I know it doesn't make sense, but I guess it does to her LOL
Thanks for all of the help guys
I would invest in a set of tires right away, but I just got new tires last year and they only have about 1000 miles on them. I was looking into the new nitto road race tires, they are pretty cheap compared to some others but how good are they?
heres my experience with jap cars vs. my TA. i have some susp. work, ie: koni SA, strano springs, STB, 35mm solid front bar, and 710 slicks. a guy i race with in my local autox club has a bone stock S2000 (not sure of the year). with my setup and tires, i could consistantly beat him on most of our autox configurations. beat him within a second or so, that is. this season, all he did was buy rims and tires. hoosier A6s. now, he is usually 2-3 full SECONDS faster then me. this is from tires only, and i was also just having a bad year this season.
now, this past sunday, e-town opened up their new road course free to try out. i went with my TA and street tires. one of my run groups had what looked like a fairly raced out S2000. hard top, big rims, high perf. tires, brakes, lowered (suspension work), 5pt. harness. it wasnt too riced out, but more raced out. although there was no passing allowed (it was just a free fun run), i could easily walk him on the straights. i had to let up every time i was behind him. if there was passing, i know i could have put a length or two on him, and taken the position before the next turn. im fairly sure the course was small enough that i could have kept him behind me until we hit the straight again. this was a rather small course, set up like a big autox, but it shows to some degree the differances between our cars and a little rice box.
considering this guy had a better car for racing, rear wheel drive and more work/expeirance then your friend, id lay a safe bet that youd **** all over him on a real road course. do some basic autox/safety mods, get some good tires, and spank him.
Heres what I'm looking at for tires....
Falken RT-615- $153
Nitto NT555R II Extreme- $186
Nitto NT-01- $198
I know theres more, but I think the Falkens price looks good. Are they a decent tire for now until I have more money to get a better tire. Also if these are used on the street what kind of a life will they have? I don't DD my car, only on nice summer days but I try to get at least 10K on it per summer
any of those tires will be fine on the street, or on the track. however, getting 10K+ per summer AND racing will chew them up in no time, and youll go through a set of tires each year, no doubt. im actually looking into getting a set of rims with falken 615s already on them just for a nearby road course. add them to the 710s i have on another set of rims, PLUS my street/show rims with street tires.....you can see where im going with this.
falkens are probably the best bang for the buck, all around. ALOT of imports use them. they are good on our cars, but i have heard on frrax.com (check it out -all f-body road race and autox forum) that with our much heavier weight, theyll get hot and squirmy on a track. would probably fare better at an autox, with lower speeds, shorter run times, and more cool down time. my guess would be the NT-01 would be the best on a track/autox, with some street use. as in driving to the track, not really all summer.
dont worry about getting 315s until you get more time and exp. into racing. its more trouble and expense then theyre worth at this point. quality 275s will be fine for learning the first year or two. dont forget buying all these tires and rims add up. 315s, in any flavor, are usually $40 more per tire then 275s. plus, EVERYONE makes tires in 275-40-17. you can get anything you want in them. 315s, while popular, arent as vastly used.
dont forget if youre at a track, youll have to upgrade your brakes, first thing. at the fun run i listed before, i had all of TWO track runs.....and my stock brakes are absolutely cooked to the point of being unsafe on the street. look into upgrading your pads, and adding brake ducts. hawk HPS or HP+ is a great starting point. just get plain, blank solid rotors. GM, brembo, even autozone brand. one theory is to get cheap, no-name **** pads and rotors, use them for ONE track day, then toss them. you can turn the rotors, but they may be warped, and the pads might be shot anyway. the other theory is to upgrade and add cooling for your brakes. spend more in time/money, but theyll last alot longer.
swapping to race fluid, like Motul 600, and stainless steel brake lines will also help alot, and should be done along with any brake upgrade/changes youre doing.
I plan on getting into the racing slowly, but I hope it progresses into something bigger. Most people around here have drag cars, but the closest track is about 3 hours away. Doing an autox setup would be way more badass IMHO and I can still go plan in a straight line with the rest of the fools, just playing. But there aren't really any events around here, but there are alot of nice low traffic twisty backroads that can easily be blocked off to have fun on. Not saying I'm going to have races on the highways but you can still mess around without too much trouble. I'm going to look into another set of 17s and see what I can do for race tires, then keep my wheels with the street tires so I don't go through 2 sets of tires a summer.Thanks again man you have been alot of help
