Crank Bolt
Its alot of work to move the steering rack and everything else. I think your asking for it to happen again by not pinning the crank.
TTY is risky and unnecessary for that application. Head bolts I can see the benifit, but a balancer bolt? Must have done some hiring ifrom the Dearborn area.
Hell Chevy didn't even use a bolt until '67-'68.
Interference fit balancer with a TTY bolt =
Best thing to do is get a pin kit and never worry about the crank spinning again.
Magnacharger or any of their dealers sells a kit to pin the crank.
When the pulley slips do to whatever situation it is effectively like a wrench that just backs the balancer bolt right out since the bolt is in contact with it. The crank is spinning clockwise(looking from front), the balancer is slipping(effectively counterclockwise), the bolt is right hand thread so lefty loosey.
It's kinda like what happens when a tire spins on the rim.
so the moral to this story is if you are running 450+hp then you need to pin the crank.
