where to put BOV on incon kit for good airflow
Choice 1 would look like this, except with another BOV on teh passenger side:
http://s94.photobucket.com/albums/l8...t=newsetup.jpg
I like the idea of putting them here for good looks and ease of plumbing/adjustment. The only thing I wonder is how much turbulence they would create for the air moving thru the pipe? Am I worried about nothing?
The other choice is to put them lower in the legs, where the airflow is straight but that would hide them and make them harder to adjust if needed.
I don't know the function differences of one bov vs two or if there is any so i guess this doesnt really help.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Just looked at the pic .You should be able to put one on the bottom side near the throttle body?
Apparently you are not that familiar with FI. You put the blowoff valve close to the throttle body to get rid of that surge of air when you close the throttle body.As fas as blowing off cooler air,it will alway's be cooler after the intercooler,so you are not waisting cooler air.
Reason for using 2 BOV is this is a twin turbo setup and I wanted to keep everything balanced, and personal preference.
I would put it after the intercooler or on the intercooler if possible.imoa.
option 2 is great for stealth, but I am not sure how much road debris would get kicked up into the BOV
option 3 might work if I want to ditch the MAF, which I am not sure yet
option 1:
http://s94.photobucket.com/albums/l8...t=IMG_1346.jpg
option 2:
http://s94.photobucket.com/albums/l8...t=IMG_1350.jpg
option 3:
take out the MAF and put in a straight piece of pipe, mount BOV there. Guys that have done this, how is the fitup? On my car it looks like the TB sits a good 3/4" lower than the butt pipe, making a straight piece of pipe difficult to hook up
Nobody thinks using 2 BOV is a good idea? FWIW I already have 2 of them.
http://www.classicgm.com/images/twinturbo/incon.jpg
I also Agree and have done the same thing. I put mine on a straight pipe and got rid of the MAF. Fitment is ok cause the silcone hose that connects the pipe to the throttle body can move enough to acomidate it.
The Incon Mule approach! If I recall those were 25's...
