LS2 uses 32.5lb injectors
Old Aug 5, 2004 | 12:44 PM
FinalTA's Avatar
Default LS2 uses 32.5lb injectors
I assume they will plug right in to the LS1? Good news for us dry N2O users
-Jason
Old Aug 5, 2004 | 02:22 PM
99Fbody99's Avatar
-Jason
No, they have a complety new design, Shorter and a new electrical connector.
Dave
Old Aug 5, 2004 | 02:27 PM
FinalTA's Avatar
Dave
Booo
Old Aug 5, 2004 | 02:48 PM
Mike TexaSS's Avatar
8 Sec Tuner
See the new issue of Fastest Street Car mag they have a great write up on the LS2.
The LS2 is what the LT4 was to the LT1.
Old Aug 5, 2004 | 05:14 PM
Kevyn's Avatar
... and then some when you consider the added cubes
I have been wanting to build a stroker but I am patiently awating the new block.
Old Aug 6, 2004 | 02:22 AM
BigTex's Avatar
Dave
Its the Multec II design that GM has used on their full sized trucks since 99. Thats good news for the truck guys.
Old Aug 6, 2004 | 10:54 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I don't know for sure, but I don't think it's the truck style injector.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Aug 10, 2004 | 11:38 PM
BigTex's Avatar
Take a look at these injectors on display from an LS2:
Those look like the multec truck injector to me. They could be just similar, but not exact.
Here is a pic of a set of truck injectors beside normal bosch LS1 style injectors.
Old Aug 12, 2004 | 12:00 PM
Speartech's Avatar
Actually the injectors in the top picture look more like the "flex fuel" injectors than the standard truck injectors. Even the flow rate sounds about the same (32.5# vs 33#).
Unfortunately they use a unique connector also, which makes swapping more than plug and play with either the LS1 or the regular truck engines.
Here's a view of all three side by side with the required connector bodies:
__________________
www.speartech.com
Old Aug 12, 2004 | 12:45 PM
slow's Avatar
is that last injector similar to the 99+ mustang pencil style injectors? looks to be a similar plug, but can't really tell from that pic
Ryan
Old Aug 12, 2004 | 03:27 PM
Speartech's Avatar
I would say yes. I don't know the specifics on the mustang, but Ford does use that injector connector on some of its applications.
__________________
www.speartech.com
