LS7 springs question
Old Feb 10, 2006 | 06:35 AM
tdrumm's Avatar
Default LS7 springs question
Will LS7 springs work on a Gen III head? What lift are they good too, .600?
Old Feb 10, 2006 | 01:27 PM
Greg Fell's Avatar
They should work, but the installed height will be lower, which will increase the pressure on the seat. That could be a good thing however.
Old Feb 10, 2006 | 02:34 PM
DrkPhx's Avatar
According to an article in Hot Rod last month they used the stock LS7 spring with titanium retainers for the LS7 Stage III hot cam with .630 lift. I was wondering the same but would be worried about possible coil bind.
Old Feb 10, 2006 | 08:49 PM
ChucksZ06's Avatar
As I recall those titanium retainers were unique in that they allowed more travel in the spring in order to get by with the higher lift.
Old Feb 11, 2006 | 07:20 AM
Pumba's Avatar
The LS7 cam has .591 inches of lift at the valve.
Old Jul 31, 2006 | 05:08 PM
texinteg's Avatar
So can I use these springs with a cam that has about 590 lift in my ls1?
Old Jul 31, 2006 | 06:43 PM
blue99SS's Avatar
^^^ wondering the same thing
Old Aug 1, 2006 | 07:44 AM
texinteg's Avatar
Anyone?
Old Aug 1, 2006 | 08:37 AM
Greg Fell's Avatar
Sure. Also consider comp 918's.
Old Aug 1, 2006 | 02:24 PM
blue99SS's Avatar
I have done a few searches and it seems that no one has really tried to put the LS7 springs on an LS1/6 yet. Anyone else?
Old Aug 1, 2006 | 02:26 PM
Haans249's Avatar
They will fit, but install height will be lowered since the LS7 valves have longer stems. There is your answer =D
Old Aug 1, 2006 | 02:44 PM
blue99SS's Avatar
So that means you won't get the full .591 lift then, is that correct?
Old Aug 1, 2006 | 02:53 PM
Haans249's Avatar
That is correct, the coil bind will be lower, so the max lift will then suffer
slow67's Avatar
Gingervitis Addict
1.959 in installed height - ls7 Installed height
1.805 in installed height - ls6 installed height
assuming .630 lift was the biggest safe lift without coil bind:
1.329 in for max lift
1.805 - 1.329 = .476 travel
Unless someone knows the actual coil bind, I would be wary of putting this in my motor.
Old Aug 1, 2006 | 06:51 PM
blue99SS's Avatar
So how big of a cam do you guys think you could go with these springs before coil bind? What are the pro's/con's of the extra seat pressure?
