just got my LS1 for my subaru WRX
Old Sep 28, 2005 | 10:40 AM
  #61
LS1_boostdscoob's Avatar
yeah we moved it down till the oil pan is clearing the member , and its almost level with the hoodline.. the firewall is gonna need a bit of clearancing but nothing big...
Old Sep 28, 2005 | 03:51 PM
  #62
digitalsolo's Avatar
Should be fun, those are stock 98 LS1 heads though, same ones as my swapped engine has.
Do you have a goal date to have it moving under it's own power? (done is never the right word here, what project car is ever completed? )
Old Sep 28, 2005 | 04:46 PM
  #63
stevieturbo's Avatar
Originally Posted by redmist
The primary weight reduction comes from the loss of the 4 wheel drive.
You lose 2 front driveshafts. I wouldnt call that a weight reduction. The T56+LS1 will be a lot heavier than the Subaru engine and box, as both are relatively light.
Originally Posted by LS1_boostdscoob
werd... i was contemplating the STI rear diff with maybe even a quaiffe...theres stock ones running like 600 hp on them so they should be able to take some abuse with a quaiffe
Dont forget that power is going through 4 wheels, and front and rear diffs.
The standard R-160 diff in a WRX is not at all strong ( I believe sone Nissan/Datsuns also use an R-160, which refers to crownwheel diamater in mm )
The latest STI uses an R-180 diff, which is stronger, as are its driveshafts etc.
an R-180 rear end will bolt straight in, but buy complete with shafts and hubs etc.
Tallest rear end ratio is a UK/Euro/US spec STI which has a 3.54 rear end.
Jap specs will have a 3.9, as they use a different transfer box.
Old Sep 28, 2005 | 05:15 PM
  #64
LIL SS's Avatar
Originally Posted by smokinHawk
there you are, i figured youd be on here.
and i told you those are 97-98 heads
https://ls1tech.com/forums/showthrea...ht=casting+806
not ls6 aka z06 heads
it looks like you have the zo6 intake manafold. as there is no EGR present.
plus you have a 98 style water pump.
since your adding boost id try to get some 6.0L heads bigger CC will alow for more boost.
All of this just to beat a turbo mustang
But perhaps that is not even an LS6 intake and just a plain jane 97-98 Corvette intake. The C5's had a EGR less LS1 intake.
Personally with the 97-98 heads and that intake, I think you got just a plain jane 97-98 LS! out of a vette. Not a Z06 motor. Pull the heads off and take a few pics of thise for us.
Old Sep 28, 2005 | 05:29 PM
  #65
will do.. im goin to do a full teardown and rebuild with new everything, good rods, and some 9.0:1 compression pistons...
Old Sep 29, 2005 | 09:05 PM
  #66
i need some sponsors... trying to finish this.. i will put your name as big as you want on my car.. just a little help would be appreciated... goin for first subaru in the 8's... help me make it true and i might just make you famous... and more $$$...
Old Sep 30, 2005 | 09:34 AM
  #67
The Rigolis down under have been running 8's for some time now.
Old Sep 30, 2005 | 09:37 AM
  #68
SatisTraction's Avatar
LOL, dont we all. you should not start a project like this if you do not have the $$$ to finish it. I would say the chance of you getting a large sponsor is 0%. what do they have to gian by giving you $$$$? you have a one off car that they will not build conversion parts for. the car manufacture sure wont give you $$$ (they would kick you in the nuts though). just slow down a little and finish the project a little slower. it will be an awesome car!!
Old Sep 30, 2005 | 07:28 PM
  #69
oh i will finish it.. just anxious...
gonna start the teardown shortly..
Old Sep 30, 2005 | 08:25 PM
  #70
LawHorn's Avatar
itll fit kind of like the munsters hot-rod. in the F-bodies the last 1/4 of the motor is halfway into the dash. Good luck man
Old Oct 1, 2005 | 08:39 PM
  #71
heres an update.. we hacked the crossmember a bit and heres how it fits now...
Size:  56.2 KB Name:  subarubuildup038.jpg
Size:  49.1 KB Name:  subarubuildup039.jpg
Size:  52.0 KB Name:  subarubuildup040.jpg
Size:  54.5 KB Name:  subarubuildup042.jpg
Size:  51.2 KB Name:  subarubuildup043.jpg
Size:  55.8 KB Name:  subarubuildup044.jpg
Size:  52.1 KB Name:  subarubuildup045.jpg
Size:  57.3 KB Name:  subarubuildup046.jpg
Size:  55.7 KB Name:  subarubuildup047.jpg
Old Oct 2, 2005 | 12:25 AM
  #72
jbk240z's Avatar
Default LS1 sub...
The progress pics look good. Congrats! Keep us posted, this will be a sweet ride when done.
Old Oct 2, 2005 | 03:10 PM
  #73
StangEaterSS's Avatar
that's just insane. a WRX w/ LS1!
Old Oct 2, 2005 | 09:57 PM
  #74
Formulized94's Avatar
sounds like an awesome swap
Old Oct 3, 2005 | 01:11 AM
  #75
thanks guys really..
i just got a guy from a fab shop whos interested in helping so i should have some pretty slickshit motor and tranny mounts.. hopefully he'll help with the 9" setup...
Old Oct 3, 2005 | 04:54 AM
  #76
smokinHawk's Avatar
all he needs to do is send $80 to some sprots compact magazine and the'll send him a check for $10,000
if you need help with the turbo piping let me know.
Old Oct 3, 2005 | 08:30 AM
  #77
redmist's Avatar
Where's the steering shaft?
Old Oct 3, 2005 | 10:07 AM
  #78
drivers side behind the header...we dropped the steering rack down about 2" and we're goin to make new mounts for it...
Old Oct 3, 2005 | 02:00 PM
  #79
gnx7's Avatar
Remember to correct for bumpsteer. Moving that rack will add another component to the conversion equation.
An R230 300zxtt/Q45 diff is nearly a 9" ring gear and is very very stout. Putting a solid rear end out back.... . Why not keep it IRS and put some upgraded 300M axles along with it? IRS cars can 60 foot awesome as well.
Maybe you should create a mid engine LS1 powered Brat with C5 transaxle instead. You could have 2 turbos mounted on a roll bar like the original KC Daylighters!
Old Oct 3, 2005 | 02:04 PM
  #80
how would i correct for bumpsteer?
