Ok wanted to check pushrod length but this is very confusing..
Now he is telling me we have to remove valve springs..I don't think so. And hearing have to get a solid lifter to test..I just put on the heads and AM NOT going to take them off to install a solid lifter not a chance..ls1 lifters are under the heads and even if they weren't not going to take off intake to install a solid lifter.
I thought just needed to buy the 20 buck tester..no idea what this guy has..
And turn it with my hydraulic lifters to zero lash or something and test that way.So whats the deal here..no one would be checking pushrod length on an already assembled engine at least I won't tear it apart to check it would take my chances. I have 7.4 moly pushrods currently.
Take the length of the tool + the amount of turns + .080(preload) and that is your pushrod length.
Example: 6.8" + .5"(10 turns) + .080 = 7.380...this is from my motor in which I used a 7.375" pushrod.
Hope this helps.
