Stock motor mounts w/ LT's ?
Old Aug 1, 2010 | 05:20 PM
FASTEDDIE Z's Avatar
Question Stock motor mounts w/ LT's ?
I was thinking about getting a set of new GM motor mounts to use with my long tube headers instead of using the poly mounts . I dont want to deal with any excessive vibrations of poly .
Has anybody used new rubber mounts w/o problems on LT's ?
Old Aug 1, 2010 | 05:40 PM
1BAD02WS6's Avatar
How would it cause a problem?
Old Aug 1, 2010 | 05:54 PM
01SuperSport's Avatar
IDK how they will work but just do something about it. The banging getting really annoying sometimes. I should have got my set of poly mounts but I was TOO anxious to install my LT's
Old Aug 1, 2010 | 05:57 PM
Sommer86's Avatar
The vibration wont be "excessive". But on stock motor mounts, you'll more than likely have your Y banging into your floorboard.
I did my Y and MM's at the same time and couldn't love them more. All my friend have stayed with stock MM's and the Y hits the floorboard.
Do it right the first time and do the prothane mounts. Plus, it's a Camaro, not a Benz.
Old Aug 1, 2010 | 06:43 PM
DaveX's Avatar
I think you would later regret not going with poly mounts because the Y almost always bangs unless you are at factory ride height and adjust it for plenty of clearance. They are pretty easy to install with the headers off but a pain to install with them on. The vibration isn't that bad.
Old Aug 1, 2010 | 09:20 PM
Alright then . I will just use the poly mounts I have on top of my tool box. I dont want the TSP catted Y banging on the floor . Ive just heard horror stories about weird vibration problems , so I want to do it right the 1st time .
Thanks everybody for your advise .
Old Aug 1, 2010 | 09:43 PM
KRAZY K 2000 TA's Avatar
vibration problems from motor mounts? maybe bad u joints or other drivetrain problems.
Old Aug 1, 2010 | 10:06 PM
Sommer86's Avatar
I also noticed that when the tranny mount is done with the MM's then the vibration isn't felt (or as much).
The tranny mount will "bend" if the motor mounts are poly, and vice versa. Do them both at the same time and enjoy it that much more.
Old Aug 1, 2010 | 11:23 PM
libertyforall1776's Avatar
Except I read NOT to use poly for the trans mount, due to excessive vibration when used with poly MMs...
Old Aug 1, 2010 | 11:28 PM
RA032926's Avatar
if you grind the 2 bumps down to where they are flush with the mounting tabs and don't use the long flat washer in the kit then it won't make any noise... i would do all 3 at the same time as was stated above... if you do the trans mount only you risk breaking the trans case and if you do the motor mounts only it can cause the trans to jump around
Old Aug 1, 2010 | 11:32 PM
z99ls1's Avatar
Restricted User
Or you can bolt you exhaust after the y down to the exhaust hanger with a u bolt. thats what I did and it works great. It just holds it down enuf os it doesn't bang on the floorboard or vibrate
Old Aug 1, 2010 | 11:41 PM
X-ray's Avatar
I love my solid motor mounts. Poly motor mounts can't feel that bad.
I also love my true duals and encourage anyone to consider them over a y-pipe.
Old Aug 2, 2010 | 10:01 AM
DadsZ28's Avatar
Eddie, let me know how your TSP catted y-pipe fits. I have been thinking of replacing my ory with one in the future even though it fits pretty good but the smell is sometimes annoying, thanx.
Old Aug 2, 2010 | 12:56 PM
MikeWS6's Avatar
I did polys with lts and there is a little vibration under acceleration but not much.
Old Aug 2, 2010 | 01:20 PM
ibex37's Avatar
you should def. do the poly motor and trans mounts before you put the headers in place. i did the headers and y pipe, had the problem of the pipe hitting the floor, it was so bad i couldnt even get on it in first or second. then i put the motor and trans mounts in and the difference was night and day, the banging went away completely and the vibrations were minimum at best, even with the a/c on the car is completely liveable, i daily drive the car and cant say i notice them any more. i just can express enough how much more difficult it is with the headers in place. learn from my mistake or curse yourself later.
Old Aug 2, 2010 | 09:38 PM
TXZ28LS1's Avatar
im also running my stock motor mounts. im running a cam, and all bolt ons and i have no problems at all. ive been running with stock motor mounts for almost 3 years.
Old Aug 2, 2010 | 09:59 PM
STREET99's Avatar
Im running stock motor mounts with LT's into a ORY with a 3inch bullet w/turndown and I have no vibration problems at all..
Old Aug 2, 2010 | 10:07 PM
garygnu's Avatar
I think the extra heat from the headers break down and weaken the stock motor mounts.install poly motor and trans mounts.don't use solid mounts on the trans!
Old Aug 3, 2010 | 09:55 AM
Will do ! Theve been sitting next to my toolbox for 2 months now . Going to install them in September .
