The truck ignition coil upgrade
Old 04-12-2014, 05:16 PM
  #81
That's MISTER MODERATOR
Paul Bell's Avatar
Originally Posted by Spectre86
are these coils still the same current ones being used now or was there any changes since this thread was made?
I'm not sure what GM is using as the "current" coil setup on any vehicle. I think what they use is partially driven by what OEM supplier offers and their cost to GM.
Old 04-12-2014, 05:20 PM
  #82
Paul Bell's Avatar
TRUCK BRACKET IN STOCK LOCATION ON STOCK VALVE COVER:
Sommer86 (11-09-2020)
Old 04-12-2014, 05:21 PM
  #83
Paul Bell's Avatar
UN-MODIFIED BRACKET IN "STOCK" LOCATION ON TALL VALVE COVER
Old 04-12-2014, 05:23 PM
  #84
Paul Bell's Avatar
BRACKET BEFORE AND AFTER MODIFICATION
Old 04-12-2014, 05:24 PM
  #85
Paul Bell's Avatar
MODIFIED BRACKET ON TALL VALVE COVER LOWERED
Old 04-12-2014, 05:25 PM
  #86
Paul Bell's Avatar
6MM HARDWARE, STANDOFFS, SEALING WASHERS
Old 04-12-2014, 05:26 PM
  #87
Paul Bell's Avatar
MODIFIED BRACKET ON TALL VALVE COVER IN LOWER POSITION
Old 04-12-2014, 05:27 PM
  #88
Paul Bell's Avatar
BOLTS FROM INSIDE
Old 04-12-2014, 05:28 PM
  #89
Paul Bell's Avatar
COILS MOUNTED
Old 04-12-2014, 05:29 PM
  #90
Paul Bell's Avatar
ANOTHER LOOK
Old 04-12-2014, 05:38 PM
  #91
Paul Bell's Avatar
The only 6mm "standoffs" I could find was threaded rod couplings which were way too long. I cut them to 1/2 inch lengths. The wide/flat head screws were also too long and I cut them to 5/16 inch. They worked out well as they had a #3 Phillips drive. Each one got a drop of red thread locker making them and the standoffs pretty much permanent.
Moving the brackets down on the valve covers eliminates any interference issues with the fuel rails.
SweetJohnny (07-22-2023)
Old 04-13-2014, 01:50 AM
  #92
LS2Ttype's Avatar
I have a set of the Newer style LS2/LS3 coils and brackets and valve covers, all complete with coil valve cover harness too, They came off a low milage 07 LS2 Vette , I wanted to replace my stock LS1 coils on my 01 SS, I would swap out the valve covers too since everythink is all together on the covers already. I think the LS2 coil harness will plug right into the cars main plug, But not sure if the coils would be wired right, i heard something about maybe other coils besides The LS1/LS6 coil using a older F-body ECM would not work right, But im not 100% sure, I would love to put them on the newer style coils look much nicer and are a very clean look
Old 04-13-2014, 08:13 AM
  #93
Paul Bell's Avatar
What you have will bolt & plug directly to your engine and run fine.
HOWEVER, it's not an upgrade, you'll see no performance improvements.
Old 04-13-2014, 11:02 AM
  #94
LS2Ttype's Avatar
How do you Know? have you tested these newer coils on a LS1 motor?, any run times with miles?
I would love to swap my old ulgy LS1 coils out for the new ones this spring
Old 04-13-2014, 12:31 PM
  #95
Paul Bell's Avatar
Tests were performed by Mega Squirt. The truck coils with the heatsinks (which is what this entire thread is about) were the only ignition coils that showed a higher output in joules. It's also noted that these coils are capable of better dwell but the PCM must be programmed to take advantage of it.
All other coils have similar (lower) output & performance regardless of year or engine they came on.
These truck coils can produce a hotter and longer lasting spark when compared to other coils. It's a very popular upgrade with the FI crowd.
Old 04-13-2014, 12:37 PM
  #96
Paul Bell's Avatar
Reminder folks: This thread is about upgrading to the higher output truck ignition coils with the heatsink.
Discussions about other coils should be posted in the external genIII or genIV sections.
Old 05-21-2014, 09:10 PM
  #97
perry67's Avatar
Default [QUOTE=Paul Bell;12985321]The truck ignition coil upgrade:
I have a 5.3 truck engine and not sure if it has the coils you refer to. I assume if it does not the upgrade would improve the 5.3.
Thanks Perry67
Old 05-21-2014, 09:19 PM
  #98
Paul Bell's Avatar
Hey Perry, welcome to LS1tech!
The "better" coils are the truck coils that have an exposed aluminum heat sink on the top end. Shown in this post:
https://ls1tech.com/forums/17514054-post27.html
Old 06-15-2014, 11:20 AM
  #99
Tyrd_Fyrgus0n's Avatar
Question
Swapping these coils into a LS1 equipped engine in a Camaro/Firebird has shown improvements in horsepower and torque. The same improvements should be seen in a Corvette or even a GTO. Some car owners who’ve done this swap have also reported better throttle response, engine smoothness and fuel economy. A few have done back to back dyno pulls to document the results. Power improvement results can vary from an increase high of 9 rwhp/18 rwtq to a low of 6 rwhp/2 rwtq. One shop showed no improvements at all. Obviously, results will vary and may be affected by other modifications done to the vehicle or the engine’s overall condition. Turbo shops have been using these coils for a few years, it’s even noted in the excellent publication "How To Build High-Performance Chevy LS1/LS6 V-8s" (you do have a copy of this book, right?)
I just bought a copy of this book, and on page 49, where it discusses this it says:
"In fact, the stock coils have been known to handle over 1000-hp turbo applications with no problem. They've gotten a bum rap from the blower and turbo crowd as many claim the coils struggle to handle high-RPM, big number power. Actually, the problem is not the coils, but with the spark dwell timing.
On boosted engines, the dwell needs to be lengthened at higher RPM but kept near stock levels at low RPM to avoid overheating the coils."
He does say "may engine builders believe the round truck coils perform better in high-horsepower applications than the other two coils," but … sounds like maybe he doesn't believe this himself?
I'm admittedly a noob, and I certainly am looking for advice on coils, wires and plugs for my currently stock, but soon to be bolt-on upgraded LS1. Sounds like from the book that's being quoted as the reference for this that the coils aren't worth the effort.
Anybody have dyno numbers that show an improvement for a non-boosted engine? Or is there another motivating factor like reliability?
Old 06-15-2014, 01:36 PM
  #100
Paul Bell's Avatar
Welcome to LS1tech!
Results on the dyno vary from more power to less power so it's your call. More power or not, my engine seemed to run a bit smoother after the swap and a tune for them. I would still do the swap today if I got another LS car without these coils.
Nobody should expect more power from this swap but they are the better of all the coils used by GM.
Quick Reply: The truck ignition coil upgrade
