1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
Old 03-19-2016, 10:28 AM
  #241
Forcefed86's Avatar
Originally Posted by a4ls2goat
The idle valve is there but not connected, would it still cause an issue even though its not connected?
And yea, tb is all the way closed
Yes it could still cause the problem and most likely is. There is a plunger that moves in and out on the tip that controls idle speed by leaking more/less air past the TB. Most likely it's not 100% closed.
You can pull the plunger out 100% by hand and slip washers on the shaft where the spring is in the pic that way it's locked closed 100%. Finding the exact length of "A" in the pic below may take some time to figure out. But it will all make sense once you pull it off and look at it. "B" basically needs to be pushed up against the bleed hole 100% so no air can bypass the TB.
Old 03-19-2016, 10:59 AM
  #242
Tjabo's Avatar
FWIW (which is probably nothing, since I doubt the Micro has the facility, but I'm not sure), I controlled a stepper motor IAC with MS2 and MS3, and it worked very well. Still, even though MS2 is the same processor as Micro, I had to run four jumpers under the board, and I'm not sure how or if that translates to the Micro.
Assuming it doesn't, I think I also ran an appropriate sized NPT tap into a stepper motor IAC hole one time and pipe plugged it. All of this was a while ago, and my memory is feeble. Lol
Old 03-19-2016, 11:43 AM
  #243
kwrench61's Avatar
im running microsquirt plug and play ecu. it doesnt use the iac
How is idle controlled then between hot and cold conditions and from park to drive etc...??
Old 03-19-2016, 11:48 AM
  #244
Tjabo's Avatar
Whoops, sorry, I missed the Plug and Play part! Although there is probably no way to make a normal MicroSquirt control a stepper IAC either...
Old 03-19-2016, 04:17 PM
  #245
a4ls2goat's Avatar
thx for this. i will try it today to see if it fixes it.
Old 03-19-2016, 04:23 PM
  #246
dirtylark71's Avatar
I just used silicone or jb weld will work. Jam it in the hole. That's what she said.
Old 03-19-2016, 05:05 PM
  #247
a4ls2goat's Avatar
Lol. Ill do that
Old 03-19-2016, 05:37 PM
  #248
denmah's Avatar
just fill it with something, boost will blow the stepper head around
Old 03-19-2016, 08:50 PM
  #249
SLOW SEDAN's Avatar
Yea. Denmah made 740whp on 23psi on 9 degrees of timing. Lol.
My goals are 9s. Or 150mph trap speed. What ever comes first. Lol
Your goals should be easily met, that car will fly! I use the same on3 88mm on a mostly stock 5.3 in my 4k lb family car and it ran 9.6@145 on a baby soft tune the first time out with it.
Old 03-19-2016, 11:05 PM
  #250
a4ls2goat's Avatar
Nice! Do you have a build thread?
Old 03-19-2016, 11:40 PM
  #251
a4ls2goat's Avatar
Buttoned up.
Old 03-20-2016, 12:38 AM
  #252
a4ls2goat's Avatar
I plugged the iac and still having the idle issue.
Old 03-20-2016, 05:37 AM
  #253
kwrench61's Avatar
Silly question but have check entire intake for any/all vac connections/leaks ?
Old 03-20-2016, 04:44 PM
  #254
Is it running on E right now? Might have an effect somehow tune wise?
Old 03-20-2016, 05:50 PM
  #255
Forcefed86's Avatar
Has to be a leak in the intake tract somewhere. How did you plug the IAC? Any pics?
I noticed your timing was at 38* or so? Thats pretty excessive, even at low load/idle. Mine likes around 9* at idle, 28-32 in light load cruise.
Old 03-20-2016, 06:01 PM
  #256
a4ls2goat's Avatar
I checked. Everything looks good.
Ill triple check.
Old 03-20-2016, 06:02 PM
  #257
a4ls2goat's Avatar
Yea. E85
Old 03-20-2016, 08:22 PM
  #258
kwrench61's Avatar
Suggestion....spray wd40 or brake cleaner around intake while running to see if idle changes.
Old 03-20-2016, 11:51 PM
  #259
a4ls2goat's Avatar
Got rid of the ebay fan that blew air like a little biatch. Replaced it with a fan from a cavalier. Fits perfect with some trimming. This ones blows air like a baws.
Old 03-21-2016, 10:43 AM
  #260
SLOW SEDAN's Avatar
I don't... pretty typical flipped manifold, turbo cam and valve spring build.
9 is pretty low and 38 is pretty high for idle, most I've seen like 17-22.
Quick Reply: 1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
