1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
#263
I’d suggest pressurizing the whole system with shop air and hosing it down with soapy water. If no major leaks show, take another look at the idle bypass port. Curious how he blocked it off…
#265
Drove it for about 15miles. Stop and go traffic, 92 degrees here in AZ right now. And didnt see over 208* fan seems to be doing good.
I dropped the timing to about 13 at idle and it idles alot better. Doesnt hunt for an idle anymore. Thx for that forcefed!
#269
#272
Took it for a long ride. Drove it for about an hour or so
For some reason my alternator is not charging. It shows 14.5 volts with it running and never drops, but the second i turn the car off and try to start it again the battery is drained.
i have the brown wire plugged on the alternator to a 5 volt source with a light bulb instead of the resistor.
any help on this?
any help on this?
#274
I'd be blown away if that little radiator and fan keep your setup cool especially once you start making some boost pulls.
As suggested the 3.8i Taurus V6 fan kicks serious ***. I believe it is rated at 4000cfm. I run one and it does suck
The car does look mean as hell though!
#275
What year alternator?
So with a volt meter the alternator is charging 14v and if you shut the car off, then immediately try to turn it back on the battery is dead? Or it's draining the battery down over time when it's off?
I use 12v to the brown wire with a 500 ohm, 1/2 watt resistor which drops voltage down to 8.x I believe. Never had an issue. I believe its the older 98 camaro alternator though.
#276
My volt guage reads 14.5 with it running, never drops while im driving. But than when i shut it off after driving for a while the battery is dead.
#280
