67 Chevelle ls1 t66
Old 03-07-2016, 09:05 AM
Haddixj's Avatar
Frame back from powder coating. Now waiting for the bushings to get it back to being a roller
Old 04-10-2016, 03:32 PM
Haddixj's Avatar
i will metal work all the dents, the tunnel is made out of 18 guage that I formed in a slip roll. I have butt welded the panel around and will finish weld it once I form the rear piece and pull the engine and trans.
Old 04-11-2016, 03:53 PM
dan96z71's Avatar
Looking great!
Old 04-17-2016, 12:52 PM
Haddixj's Avatar
Got the rest tacked in. I need to eliminate the skip shift solenoid or cut it up. Need to do more research on it.
Old 05-07-2016, 05:29 PM
Haddixj's Avatar
Vintage air evap hung with studs welded in. Also modified the firewall for the American autowire harness.
Started modifying the dash for the vents. I'm thinking of leaving the wood grain strip off and just welding up the holes and mounting the center vents directly into the dash. I am going to reprint the dash when it is done. I am trying to figure out where to mount the pcm and the Dakota digital stuff. It's going to be a tight fit so I figured I better get the a/c mocked up in place with the hoses ran then try and fit everything accordingly.
Old 05-10-2016, 01:35 PM
dan96z71's Avatar
These are my soon to be steps as well...have to get my trunk and mini tubs done, then on to dash and tunnel work...or quarter panels...or both
Having the 66 with the removable dash helps...With the 65 I get to try to fix all my rust issues behind the dash while it is still in there. yuck!
Might be stealing some ideas from you
Old 05-10-2016, 02:24 PM
Aston Tibs's Avatar
Good move running the AC hoses and stuff prior to mounting the ECM. By the time I was done running the dash harness and the AC lines and hoses it was like 10 lbs of **** in a five lb bag.
Old 05-11-2016, 09:45 AM
Haddixj's Avatar
I am going to get all the mechanical stuff bolted in and then try to see where the wires will end up. I may end up putting the ECM under the pass seat.
Old 05-16-2016, 11:30 AM
Haddixj's Avatar
All the vents fitted in
I blasted and epoxy primed the dash with ppg dp50lf. I welded up the holes for the wooden strip and am going to paint it gloss black like the rest of the interior and see how it looks.
I blasted and epoxy pried the dash with ppg dp50 primer. I welded up the holes for the wooden strip and am going to paint it gloss black like the rest of the interior and see how it looks.
Old 05-16-2016, 11:34 AM
Haddixj's Avatar
not sure why it double posted, I posted it from my phone sorry
Old 05-21-2016, 03:51 PM
Haddixj's Avatar
Patching the firewall where the slave cylinder went through.
After measuring and trying to figure out the best angle for the clutch rod I ended up grinding most of the peddle away and drilled a hole in the existing pedal mount.
How much was grinded away
I split a piece of tube and welded it in as a gusset and pass through for the rod. I also added another gusset on the back side so it would have more steel then when I started.
Old 05-22-2016, 09:50 AM
dan96z71's Avatar
How would you end up getting that bolt out of there? Seems like you would need to cut a hole in the tubing piece so the bolt can back out all the way?
Old 05-22-2016, 03:14 PM
Haddixj's Avatar
Hard to see from the pic provided above but the bolt is in front of the brake pedal by about an inch.
Picture shows it a little better.
Old 05-22-2016, 06:31 PM
dan96z71's Avatar
I see it in the first pictures now.
Old 05-23-2016, 09:15 AM
1964SS's Avatar
I'm amazed at the differences I've seen on the master cylinder mounting rod. On my 64 the master cylinder rod is actually spaced over from the right side of the pedal. We did my buddies 66 chevelle this weekend and his is flush with the right side of the pedal. There must be some differences in the brackets sold for mounting the masters.
Old 06-07-2016, 08:45 PM
Haddixj's Avatar
Firewall in high build primer. Just putting glazing putty on the last bit and hope to shoot color sometime next week. Then hopefully the progress will be faster. Car is supposed to be done for hot August nights so gotta start moving faster.
Old 06-16-2016, 08:57 PM
wlsmoku's Avatar
very nice work!
Old 06-19-2016, 11:43 AM
Haddixj's Avatar
Final sealer
Base
Clear<br/><br/>Sorry for the horrible lighting I will take some outside pics once I cut and buff it.
Old 06-23-2016, 08:59 AM
  #39
Haddixj's Avatar
Outside still needs a cut and buff
Painted the dash in single stage
Old 06-23-2016, 09:00 AM
  #40
Haddixj's Avatar
So far I have the sound deadner put in the inside and a/c hung back on the firewall. Now I need to start the process of putting everything back together. Hopefully next week can start on wiring
Quick Reply: 67 Chevelle ls1 t66
