1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
#465
First off, the pistons would have to have the receiver groove to accept the wrist pin snap ring. Typically, pressed pin pistons don't have the groove. Secondly, sneak inside and use you a food scale to weigh the gen 3 and gen 4 pistons. If they're close and have the groove, no problem. Why not just use the ones on the gen 4 rods?
#470
Think I paid something silly like $35 for one. The last 4.8 I built had 1 damaged rod/piston.
Yup was this one. Floating pin, flat top. Same for 4.8 and 5.3
http://www.ebay.com/itm/GM-OEM-Engin...xW4bpR&vxp=mtr
Basically more expensive than the hyper speed pros that look beefier.
#476
Those noodled up rods kill me!
Did you weigh the respective piston and rod combos to see if/how your bob weights changed? (just for the fun of it that is, I don't expect you're going to go back and have the crank balance changed if this truly is sloppy mechanics style)
