Kenne Bell LSX 1970 Camaro
The Patient
Old motor Fuel injected 383 510hp
Custom Cam motion cam By Pat G
112lbs monster
Cleaned up LS3 heads with all new goodies
Wiseco and K1
Main studs
Bored .030
Leaving machine shop.
Shiny parts
Belt routing
Tight fit
Tight everywhere
T56 shifter and custom boot
Old pic but tips mocked up, fuel cell in trunk now
fresh from paint shop
I have been considering a supercharger conversion.
but the problem is that i have limited space in my truck.
Can you tell me how much higher the engine gets with the KB, instead of the stock intake.
otherwise from the crank centerline to the top of the intake.
I have 3" clearance, which cant be changed.
As far as hood clearance, my 3" cowl wouldent clear so I had to order a 4". Its about 1 inch taller than the truck intake. I got the kenne bell and my top end used and got a screaming deal or I would of went whipple. No doubt I would have had way more room, as the kenne bell mammoth is well mammoth lol. Wish I could find a girl around here even into cars, they are all into diesel trucks now. The rear is next on the list I have a donor 9" behind the garage but the 10 bolt has been solid this far, although it is built. Dougs header fits really good when I set the motor back i did have to ding one header tube but other wise much better than the original hedman I had on the sbc
The Patient
112lbs monster
Wiseco and K1
Main studs
Bored .030
Shiny parts
Belt routing
Tight fit
Tight everywhere
Kenne Bell LS Swap 1970 Camaro - YouTube
First start Kenne Bell LSX Swap - YouTube
If you're just making a comment or asking a basic question, you don't have to quote a post that has 10 or 15 pictures in it. If you click the "Edit" button you can remove the extraneous quotes to clean up the thread. The car's nice to look at, of course, but all the repeated pictures just make it harder to navigate on a smaller screen.
