Kenne Bell LSX 1970 Camaro
Old 07-24-2016, 03:28 PM
TXsilverado's Avatar
how did the dyno tune go? where are the numbers?
Old 07-24-2016, 11:47 PM
bmf5150's Avatar
Curious what you dyno
Old 07-26-2016, 07:43 PM
973800CamaroRS's Avatar
Dyno and overall motor has been nothing but issues. Thrust bearing is wiped out after 100 miles, the motor was never right from the get go. So motor is back out getting fixed and a bigger set of heads shooting for 700 !
It did put down 620rwhp at 6300rpm, with the reluctor fighting back and forth with all the endplay. Unsure what it would of really made if 100%
Old 07-28-2016, 11:14 AM
Jimbo1367's Avatar
Who built it?
Old 07-28-2016, 02:37 PM
Local machine shop that does a ton of race engine. Mostly SBC, BBC stuff but does probably 50-75 ls a year.
Old 07-29-2016, 12:08 PM
that sucks. I have a 69 with a 408 LS;3.6 KB combo. I've driven it a little but it's still not finished.
Old 07-30-2016, 05:45 PM
jimmyg's Avatar
Are you sure it's not a throw out bearing issue? I've heard of thrust bearings getting wiped out on 6 sp swaps due to clearence issues with trans/ motor
Old 08-01-2016, 08:19 AM
rjb2968's Avatar
Asides from Dougs headers, have you heard anything about using headers made for a fourth gen in a 2nd gen? I'm doing a similar swap and am trying to stay on a budget and heard you can get away with just bending the collector
Old 08-01-2016, 11:16 AM
Jimbo1367's Avatar
4th gencheaders can be done but heating the and twerking the collected needs 2 be done. Not worth the effort in my book.v
Old 08-02-2016, 01:59 AM
8 Second Truck Club
Blown06's Avatar
Just an fyi, thrush bearing issues come from problems behind the flywheel/flexplate 99% of the time.
What I'm getting at is this......make sure the rest of your driveline is good to go before you put the new motor in otherwise you'll just be repeating this process. Doesn't matter who is building the engine.
Old 08-03-2016, 07:33 AM
Going different clutch to see if maybe the pressure plate was made to tight, it was always hard to push in but engages and felt ok. also going to recheck front supercharger pulley alignment. input isn't bottoming out, and driveshaft has plenty of slip yoke.
Old 08-03-2016, 07:34 AM
  #32
I have a bushing but ffrom what I can tell it isn't harmed in anyway. hasn't been pushed in or egged out
Old 08-03-2016, 08:05 AM
  #33
dojob's Avatar
Originally Posted by 973800CamaroRS
Great looking car and setup. Sorry about the engine misfortune.
Love that you went with Kenne Bell. They are tremendous SC's.
Once you put the motor back in the car though, run the intake filter to an area away from the engine, perhaps by the headlight. You're getting lots of heat soak with the filter mounted against the engine and above the headers.
Old 08-03-2016, 08:19 AM
  #34
Yea I made an intake for it that moved it into the l/f fender area. may end up boxing the filter too.
Old 08-03-2016, 09:05 AM
  #35
dojob's Avatar
good stuff
Old 08-14-2016, 07:54 PM
  #36
Don't replace parts upgrade them. Wanted to do heads when the motor was built but didn't have the funds so I did it this go around, PRC LS3 260 heads, mcleod dual disc and bigger fuel rails.
Old 11-06-2016, 10:44 PM
  #37
zamora7's Avatar
killer build man, im working on a second gen as well but not as crazy as yours lol
Old 11-07-2016, 06:51 AM
  #38
jimmyg's Avatar
I can't wait till you get this going again. Are you running a heat exchanger? How big is your resivour? Im curious to see what the iats will be. I have a Whipple 2.9 and mine run 20-25 over ambient.
Old 11-10-2016, 10:30 AM
  #39
from my short time with the 3.6, the IAT is shitty. meth required. I have a 5 gallon resivoir and 2010 Camaro exchanger. i'm not sure which intercooler is inside of the blower. they have a new and improved piece but I cant spend that much on it.
Old 11-10-2016, 11:24 AM
  #40
jimmyg's Avatar
I have an Afco w/ fans built for a gt500. If you look at speedway.com in the garage sale sec. there is always deals on heat exchangers . I payed 500$ retails for 800$ . Came with harness, relays , etc . You could prob get an upgraded Camaro one . I think the fans will help a lot.
Quick Reply: Kenne Bell LSX 1970 Camaro
