1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
Old 05-01-2016, 10:45 PM
  #481
a4ls2goat's Avatar
Gona keep timing at 12*. 23-25psi than hit the dyno asap.
Old 05-03-2016, 12:36 AM
  #482
a4ls2goat's Avatar
Ready for test drive tomorrow.
Old 05-03-2016, 03:15 AM
  #483
dirtylark71's Avatar
Siiiick! Burnout video?
Old 05-03-2016, 11:37 AM
  #484
svslow's Avatar
Sorry if I missed it, where did you get the pistons from?
Old 05-03-2016, 11:42 AM
  #485
a4ls2goat's Avatar
Old 05-03-2016, 02:50 PM
  #486
SLOW SEDAN's Avatar
Looking forward to this... Not sure what your goal is but I would think at 13* and ~24PSI it should belt out 800whp. Even more hp if its out flowing the On3 88!
Old 05-03-2016, 04:04 PM
  #487
a4ls2goat's Avatar
Up and running.
Feels torquier forsure. Gona put some miles on it today to make sure its good.
Old 05-04-2016, 12:24 AM
  #488
a4ls2goat's Avatar
Old 05-04-2016, 01:05 AM
  #489
Haha that thing is awesome. I would be confused as **** if I didn't know anything about cars. Looking good man, can't wait to see a number out of it
Old 05-04-2016, 01:12 AM
  #490
a4ls2goat's Avatar
Lol. Thx man. I put about 50 miles on it today. Everything seems good.
Old 05-04-2016, 07:03 AM
  #491
Tomhames's Avatar
Excited to see some track times & numbers.....
How did you get the air out of your top radiator hose?
Old 05-04-2016, 07:10 AM
  #492
a4ls2goat's Avatar
I always just top it off with coolant and leave the radiator cap off while its running. Once it pushes coolant out of the radiator when it starts warming up i put the cap back on.
It has always worked for me like this
Old 05-04-2016, 09:37 AM
  #493
Forcefed86's Avatar
Looks great! Did you weigh the new pistons vs the old with a gram scale by chance?
If you really want to get the air out get a big burp funnel and let it run up to temp. It will push out a good 2 quarts into the funnel as it gets up to temps and then all the air is easy to see bubbling out. You'd be surprised how much air is usually trapped in there. Sometimes takes 20-30 mins before all the bubbles stop.
Old 05-04-2016, 01:55 PM
  #494
roastin240's Avatar
This car is sweet. My next build is going to be as sloppy as possible. The goal will be to run single digits for under 10 grand including purchase of car.
Keep this thread going. Glad to see these pistons in a car that will really be pushed. I think you should get a kick back from speed pro because I have a feeling they will sell a bunch of these if you prove their strength.
Old 05-04-2016, 07:09 PM
  #495
a4ls2goat's Avatar
Rad air purge - YouTube
I didnt.
Old 05-05-2016, 12:27 AM
  #496
a4ls2goat's Avatar
It survived!
12* timing. 23-24psi.
Had to crank the fuel pressure to 70psi base. 94-95ish on boost.
Injectors are right about 130-135% idc.
Yes, i know this is not the way to do things with the injectors but plenty of people do it and it works.
10.5-10.7 afr up top.
Feels like a complete animal.
Set the antilag at 2900rpm and i can build 4psi. As soon as i launch it blows the tires off.
Motor felt great and i did about 15 pulls back to back and it didnt skip a beat
Old 05-05-2016, 01:25 AM
  #497
a4ls2goat's Avatar
Shitty vid.
Old 05-05-2016, 01:36 AM
  #498
a4ls2goat's Avatar
Quick run down of the setup.
E85 CORN
2004 5.3l (gen 4 rods, speed pro flat top pistons)
216/220 trickflow cam
Pac1218 springs
Ebay headstuds
Ls1 intake manifold
Borg warner s475 t6 96mm turbine
4inch downpipe
2.25in hotside
Truck exh. Manifolds.
Emusa 60mm wastegate
3inch ebay intercooler.
Ebay fuel rails
Aeromotive 1:1 fuel pressure regulator
80lb injectors
2x 380lph (bosch 044 style) fuel pumps
-8 feed
-6 return
12 gallon fuel cell
Stock th400
Revmax 3600 billet converter
Steel driveshaft
1350 ujoints
8.8 rear end. Narrowed.
3.15 gears.
26x10.5x15 et street drag radials
Fast five summit wheels 15x8
Mircrosquirt ecu plug n play
Old 05-05-2016, 06:50 AM
  #499
Forcefed86's Avatar
It survived!
Is that with both pumps on as well? Get that sucker to the track stat!
Old 05-05-2016, 07:23 AM
  #500
a4ls2goat's Avatar
Red face
Yes both pumps on
Quick Reply: 1984 rx7 5.3L turbo s475/th400/8.8 /E85 (sloppy style)
