LNC 2000 and NOS mini progressive wiring look correct?
I'm using DV32V distribution blocks and a Bus Bar for multiple ground connections.
Bigger image: http://s234.photobucket.com/user/dpa...68lzo.png.html
A couple of things we noticed in that diagram:
I would make sure users are careful about the source of the 12 volt switched power - the purge solenoid and the bottle opener are drawing current from that 12 volt switched power source in that diagram. Many vehicle interior switched source power locations likely shouldn't be used to draw that much current. Using relays to enable the purge solenoid and the remote bottle opener would allow them to get current from another source and you wouldn't have to have high current going all the way to the switch panel.
Also it looks like the way this is wired the LNC-2000 timing retard will be active (ie taking out timing) when ever the arming switch to the nitrous controller is active, regardless of if have nitrous actually spraying.
Since that controller has programmable outputs why not use one of the programmable outputs to activate the LNC-2000 timing retard only when the nitrous is actually spraying? I believe the outputs are ground type so you would have to use a relay to convert the output to a +12 volt output to enable the LNC-2000 timing retard.
We recommend this wiring because the only way to ensure that the lnc-2000 is working is to feel the timing and power come out of the car. If for some reason the box doesn't work, there's a wiring issue, faulty relay etc., I'd rather find out by the car feeling sluggish rather than blow my intake off. It's just a precautionary measure. While these boxes have an excellent track record for reliability, we typically err on the side of caution. However, this doesn't work well for race car applications because it can be hard to get up on the 2-step with a bunch of timing yanked out. If our customer needs instruction on wiring the mini to the LNC, we can provide that as well.
Can I use a 6 way fused distribution block with 6 wires leading to each of the 6 switches, and just wire the keyed 12V wire coming from the factory fuse box to the main terminal on the fused distribution block or will that over load it?
As far as testing the box that's easy. The outputs are ground triggers. Tap another wire on the circuit. I have a covered female spade that tuck under the edge of the console. When I get to the track I arm the nitrous and touch the spade on a bolt that grounds, if the motor stumbles I know it's pulling timing. Now, I have an iat tricker box ,but it's the same idea.
