best thing to use for buffing after wet sanding?
different compounds vary in how coarse or fine they cut, but your buffing pads also make a difference in cut.
There are also different coarseness foam pads which cut hard to final buff. Different companies have different color codes , most ending with black as the final. Wool buff pads are considered old school these days, but they cut pretty fast, also require more skill not to burn through with.
There are different sizes of all these things & specialty shapes for odd jobs. You didn't mention buffing tools, which I assume you probably don't have any. Rotary tools cut faster, but orbital is better for final buff. Whole nother subject here.....
If ya could post up a picture of the rim so we can see exactly what you are working with
These are the rims on the car. It's an old pic so I don't have a current one of the haze on the rim but it's not drastic, but if you're looking for it you can tell its there and it doesn't have the same sparkle and reflectiveness. I think you're right that the cone would work well here. Now if only I had something to easily clean the pockets of my rims on the TA...
