Trap MPH and ET slower ?!
I know DA/humidity will change results although this seems like too much of a change to just be that. Located in richmond va area.
Its been a few years since ive ran but the car averaged 12.4 at 110 to 112 with rebuilt stock a4 and fuddle 3200 stall. My best pass was 12.0 at 110 two years ago after performabuilt lvl2 trans with circle d 4k stall followed by two passes in the 12.2 range ( spinning) . No changes and the past two times ive been this year the car has ran 13.0 at 103?!
I did fresh fluids, spark plugs, wires, air filter and still 13s. Car idles and drives well, no smoke or hesitations. Any suggestions? If i left out any needed information let me know...
I think you can rule out D/A as the culprit. Your runs in the Fall of 2014 were in the 900 - 1,000 foot range. Your June 17 runs were similar. The D/A on your March runs was negative.
Are you getting excessive tire spin? Do you have any videos of your recent runs? I'm Captain Obvious here but it really looks like you are down on power to the rear wheels.
Gesto
No videos and looking at my 60ft and feeling the car (launch and mph) i dont have any more tire spin comparing the 12.3/4 runs with the 13s 60 and mph.
I do agree down on power...
It seems to really depend on the setup, but you could try flashing the converter from idle or just above. I don't think this is your problem as it's not usually worth .4 in the 60'. Maybe .1 difference. Something seems off. If you need us to check out the converter we can. Just know we're here for ya.
-Brian
-Brian
How many miles on the car?
The reason I ask is that last night I was at the track and realized my brakes are slightly dragging and I have about 182,XXX miles on the car. I'm guessing the old rubber lines are allowing pressure to go through upon pedal application, but they're constricting the flow back. I just ordered new braided lines and am hoping that resolves the issue. If not, the master cylinder is getting replaced.
These cars are not new anymore. Just throwing that out there.
You lost 7-8 mph in the 1/8 from your previous best. I would pull the spark plugs. one may have a hair line fracture.
Seen a friend's car do this and it was down 30 or 40 hp maybe more don't remember exactly.
his had no mis fires because it was still throwing spark just not a good one.
Easy thing to check and rule out
