P0106 error after LS6 valley cover
Old Aug 31, 2016 | 10:38 AM
FCar2000TA's Avatar
Veteran: Air Force
The car should recover immediately if this hole was causing the problem... right? I put a thicker plug on there, but the car still runs the same.
Old Sep 1, 2016 | 12:14 PM
FCar2000TA's Avatar
Veteran: Air Force
Still runs the same. I am going to take it to a shop by my work to have them do the smoke machine test for a leak.
Old Sep 1, 2016 | 01:53 PM
DANOZ28's Avatar
after changing intake manifolds i believe i was throwing a low manifold pressure error code (i think) my car ran but like it was in limp mode. my issue turned out 2 be a broken wire that connected the pcm to the back of the intake. its a very tiny wire that cost me $100 repair which took the guy 5 min to fix. goodluck! GRRRRRRRRRRRR!!!!!
Old Sep 2, 2016 | 01:05 PM
FCar2000TA's Avatar
Veteran: Air Force
Looks like the leak is coming from the throttle body where the blade shaft enters the throttle body.
