SN95 cobra 4.8 turbo build
If you change those lines to hard line, they tuck pretty neat right along that sub-frame. No trouble with heat then, as long as they have 1/2 or so of clearance to the headers.
I've got a buddy that really really wants to use his new hardline bending and flaring stuff so maybe I can trick him into making all new hardline for me hehe. That's a good idea. Also, I'll just end up re-heating the fluid on the return if it's too close. Maybe I'll just remount it in the rear instead.
I was just curious because I had not seen you post anything about it yet.
Sorry if you've posted it somewhere, but what k-member are you using?
o god, whole bunch of crap has happened between the last update and now.
Bought a new f150 lariat... 3 weeks into owning it a 15 yr old kid in a stolen car hit it in my driveway...
Anyways, I've done a little bit more to the car. Got scammed out of some heads from one of the facebook groups so I bought a set locally that had a valve job on them and were hot tanked and cleaned up with btr 660's. Put a btr stage 2 turbo cam in.
Going to start wiring up the holley and putting the flaming river in this weekend.
Bought a glenns sleeper fuel tank, strange manual brakes, -10 pushlok fuel line, Weld RTS's. Most of the parts show up next week.
mounted the mechanical fuel pump.
ripped the interior out to get to the a/c box. pulled it so i could run holley harness through the ac holes in the firewall.
heres the dash sitting on the floor lol
i reused the rubber piece from the bottom of the ac box to be my grommet. uwed abs sheet on the inside to cover up the holes.
christmas!
headers and radiator mocked into place. going to have to move the vband closer to the collector.
spent all day today cleaning the garage and moving tools and other stuff around. by far harder than working on the car, i had been putting it off for far too long.
o god another couple of months and it should be ready.
had the rear end built by a local, he did a kickass job. 35 spline axles, 9 inch ends and all the bracing that team z offers.
Added some parts to it haha
Put it in
After that was done, decided to finish the shifter
Just finished ebrake cables as well since I had to put in wilwoods due to 9 inch ends.
Put it in
