Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
pushing limits stock 6.0
Old 08-10-2016, 03:14 AM
  #161
dogsballs's Avatar
Can't please everybody. The visor, nudge bar and roof racks are for ***** and giggles. Easy to remove or put back on and cost me peanuts.
Biggest news is dyno is booked for sat week. Going to testmy e85 carb, race carb with roo16 (same as us q16) and a local race fuel blend a mate uses called ets. If we have time and a carb available maybe methanol
Old 08-10-2016, 08:35 AM
  #162
Old School Heavy
speedtigger's Avatar
I like all 3, but that Camaro is just epic.
Old 08-10-2016, 01:42 PM
  #163
TXsilverado's Avatar
every time I see this thread bumped, I hope it's dyno results. the day has finally come! good luck. I hope it makes everything you're hoping for.
Old 08-13-2016, 06:54 AM
  #164
dogsballs's Avatar
Cheers bud.
Last time for bottom end assembly. Pistons came out nice after shot peening. Had a little drama during the week when we noticed the tiniest movements on the balancer. We magnafluxed the crank but never checked its straightness. Turns out had a tiny bend in the middle with 3-5thou run-out on the nose. We remachined the mains and it's all mint now.
Old 08-13-2016, 06:10 PM
  #165
Doug G's Avatar
Fingers crossed all goes well.....
And Stewart, you get tired of that 1st gen.... I'll make room for it
Old 08-17-2016, 03:33 PM
  #166
dogsballs's Avatar
Old 08-20-2016, 11:18 PM
  #167
dogsballs's Avatar
No dyno yet. Decided to change viton valve steam seals as current ones tight on inner valve spring.
So we sorted the fuel pump and vac pump
Old 08-25-2016, 05:00 PM
  #168
dogsballs's Avatar
Old 09-19-2016, 09:39 AM
  #169
silent_assassin's Avatar
sweet
Old 09-24-2016, 03:01 AM
  #170
dogsballs's Avatar
Old 09-24-2016, 07:04 AM
  #171
Old School Heavy
Did the Mast valve covers have good clearance with the rockers?
Old 09-24-2016, 03:23 PM
  #172
dogsballs's Avatar
Not really had to hog them out right on the rail. One issue with ls3 15deg heads . Going to run a smoke machine through engine and see if they leak, otherwise will get those cheap eBay pro-form Chevrolet ones
Old 10-22-2016, 05:37 PM
  #173
dogsballs's Avatar
It's alive. Only broke it in and 2 super rich full pulls, still lots to come. 635hp@6800 and 515 ft-lb@6300
https://youtu.be/g8u38k5TxrM
https://youtu.be/mFsvpp-y7Hw
https://youtu.be/ZYrBdfzTuMM
Old 10-22-2016, 06:23 PM
  #174
Chris05's Avatar
���� rock on ! Great work sir.
Old 10-22-2016, 07:05 PM
  #175
dogsballs's Avatar
Old 10-23-2016, 09:43 AM
  #176
Bowtiedford's Avatar
nice numbers!
Old 12-12-2016, 08:02 AM
  #177
dogsballs's Avatar
Old 12-12-2016, 08:06 AM
  #178
dogsballs's Avatar
721hp@8000, 511 ftlb@6800
Pump e85, quickfuel 4150 1000cfm custom with 110jets square, slight leak in system so no vac pump, 20w50 break-in oil
Old 12-12-2016, 02:45 PM
  #179
Doug G's Avatar
very nice
Old 12-12-2016, 05:14 PM
  #180
is that oil psi correct? where does it sit at idle?
how strong is that ignition system? seems like it could easily skip a tooth on that belt and throw your timing out of whack.
Quick Reply: pushing limits stock 6.0
