Delete meeeee
Hey guys, Pan is most likely sold. $250 price was a mistake... Superchevyperformance.com has them for $315 NEW OEM GM Shipped
The Camshaft is still available
And I know $60 is fair on the LS6 Valley but I can ise it down the road and its new..
Its the part number that seems to be more $$$.. Not sure what the difference is between the 2?
List updated again
Thanks
List updated again
Thanks
Bumpity
The drivetrain is pulled and 4l60 & headlights sold but other than that the car is complete.. Interior/smaller stuff and body parts... PM or text me if you need any randoms
(716)428-1674 car is a rust free 2000 SS Slp "sticker car"
Very nice shape.. Even paint, previous owner rear ended somone & whent under the bumper... Only took out the hood/headlight and the Rad support. Unfortunately the price of these hoods made them total it.
Hood was replaced with a OEM SS but has 1 repair done (not bad at all) and the paint job was poor
I am going to start another thread for the car today... SLP grill is also gone and tail lights, no rear seats and fronts are aftermarket
Brakes/rear end & struts/springs are also sold..
Ok here is an updated list if what I have all prices are before shipping unless it says otherwise..
Located in Buffalo NY...14228
799 heads w/ 110,xxx miles assembled
$400
799 heads bare with valves
$350
853 heads bare cleaned up with valve's
$200
Dual Valve spring set up..nice quality low mileage believe to be PAC mabey Comp
$250
LS1 Intake manifold complete with out TB
$250 **SOLD**
F.A.S.T. lsx-r 102/102 w/DBC TB no rails or injectors
$900 shipped
Truck fuel rails with injectors
$100
Truck TB DBW loaded $50
LS1 TB DBW loaded $50.
F-Body Front accessory drive
With A/C $550
Without A/C $450
F-Body Oil Pan Kit..pan/tray/baffle/pic-up/dipsticks
$250 shipped. (Last one pending)
F-body Engine Wiring Harness NO ECU
$300
Truck Engine Wiring Harness with ECU DBC
$200
GM LS6 Valley Cover (new)
$75
GM LS1 Valley Cover (used)
$50
Very nice catch can set up.. Forget the brand but I have the instructions somwhere
$150 was $250 new
LS1 Fbody Poly motor mounts new..w/clamshells
$65. **SOLD**
4th gen front lower control arms with new poly bushings & harware
2000 SS Front spindles
$100ea
2000 SS Front Calipers/Slotted & Drilled Rotors & Pads basically new
$250obo
GM Rocker Arm Set. Clean low mileage.
Rockers, stands & bolts
$110
GM Rocker Arm Set (used) w/ Bushed Bronze Trunion upgrade installed. New
$300
GM LS3 Rocker Arm Set (new) w/ Bushed Bronze Trunion upgrade installed. New
$350
ATI SuperDapner F-Body spacing 25% UD 5.5" NO A/C new
$300
GM Coil Pack Sets.. Includes coils/brackets/harnesses & hardware
F-Body $125 **SOLD**
New truck $125
Old truck (heat sink) $175
LS valve cover's
Truck $50
Fbody $60
Trickflow 7.400" heat treated pushrods (lightly used)
$50. **SOLD**
CompCams hydraulic roller 230/230 .592/.592 113+2 lsa
$225
Hooker Supercomp Coated & Tunned LongTubes 1-3/4" 2469-1hkr (includes 2 like new OE style O2 sensors) $250 **SOLD**
Speed Engineering stainless steel 1-7/8" Long Tube's (new)
$250
w/new gmp mls gaskets & stainless bolts
$325 shipped
Hooker Supercomp Coated Y-Pipe with 2 Metallic Spun Stainless cats, 2 like new OE O2 sensors & O2 extension harnesses
$350
Borla AXLE BACK. With QTP electric cut out & wiring
$550
Magnaflow AXLE Back $150 no shipping **SOLD**
Mint condition OEM WS6 Ram Air hood red $1,000
2000 SS SLP CAMARO BLACK:
GM OEM SS Spoiler good shape.. Black
$300
GM OEM SS Hood, repaired in 1 corner but looks nice. Will need paint
$350
Front Bumper (no grille)
$200
Rear Bumper
$200
Fenders with SLP SS Badging
$200ea
Rear filler pannel with SS SLP Badging
$250
Doors loaded with glass/guts electrics
$200ea no shipping
Hatch no spoiler
$200 no shipping
CAR IS ALMOST COMPLETE. NO RUST. BEAUTIFUL PAINT.
ASK FOR ALL SMALLS
LS1 Engine. Complete Turn Key 6k on rebuild
Car had 151k when rebuilt. Engine pulled at 157xxx. Have running & driving videos
30lb oil prs HOT IDLE 5w30
-crank polished
-mains align honed
-cam/rod & main bearings replaced
-cylinders lightly honed
-rebuilt 243's milled .010"/-1.5cc (10.8-1)
-PAC Behivee spring's
-new GM rocker arms
-GM MLS head gaskets
-GM/Fel-pro gaskets all around
-Melling oil pump
-GM LS7 Camshaft (front cover w/cam sensor)
-GM LS7 lifters
-LS2 lifter trays
-LS1 Intake manifold complete with new rails/injectors... No tb.
With all fron drive accessory's, fbody pan & fbody harness/ ecu
$2,750
No front drive $2,000
No front drive, no ecu/harness, no intake & truck oil pan instead of fbody
$1,500
Shipping will be between $300-$400.
Compression test result's
190. 185.
190. 187.
190. 190.
185. 185.
LS6 Short block. LS2 style Rods. 60,xxx miles 24X wheel. Short block only
$1,500. Dont need to sell
LS1 Short Block, spun a rod bearing
$350
Transmission deal
-LS7 GM Clutch/ Flywheel kit, with ARP flywheel bolts & pressure plate bolts. 450 miles.. Just broken in
-ARP bellhousing bolts
-GM Performance Pilot bearing
-Centerforce TB
-PRO-5.0 Shifter
-Wilwood Master/Brake pedal Assembly or 4th gen pedal assembly
$1,000
Dale Jr (Killer's) 18x9"F 18x10"R 275 Nitto 555's all around with 65% tread life
$500
C5 Deep Dish Replica's 18x9.5"F w/275's 18x10.5"R w/295's like new 1 season on wheels&tires. Continental Extreme Contact "DW's" 90%+ tread life
$1,200
OEM WS6 Wheels with decent tires $600 no shipping. **SOLD**
4th gen fbody front sway bar 1LE with new poly endlinks & bushings
$50
PBR rear brakes with newer rotors/calipers & pads, LT1 style PBR 12" w/backing plates
$200 **SOLD**
4th gen front Eibac lowering springs on stock struts
$75
SS SLP Badging (fenders/rear filler) red
$125
New aluminum Driveshaft
$125
Used aluminum Driveshaft
$100
3.5" steel Driveshaft (brand un-known)
$225
New Rack & Pinion
$100
Ls1 motor mount stands
$60
T-Tops
$150 set
Gauge clusters
$75
TONS MORE.. cant think of everything
If you need somthing not listed feel free to ask, go ahead and make offers if youd like..
PM me or Text me with your name..
Thank you,
Adam B.
(716)428-1674
$400
$350
$200
$250
$250 **SOLD**
$900 shipped
$100
With A/C $550
Without A/C $450
$300
$200
$75
$50
$150 was $250 new
$65. **SOLD**
$100ea
$250obo
$110
$300
$350
$300
New truck $125
LS valve cover's
Truck $50
Fbody $60
$50. **SOLD**
$225
$250
$325 shipped
$350
$550
$300
$350
$200
Rear Bumper
$200
$200ea
$250
$200ea no shipping
Hatch no spoiler
$200 no shipping
ASK FOR ALL SMALLS
-crank polished
-mains align honed
-new GM rocker arms
-Melling oil pump
-GM LS7 lifters
-LS2 lifter trays
$2,750
$1,500
190. 185.
190. 187.
190. 190.
185. 185.
$350
Transmission deal
-Centerforce TB
-PRO-5.0 Shifter
$1,000
$500
$1,200
$50
$200 **SOLD**
$75
$125
$125
$100
$225
New Rack & Pinion
$100
$60
T-Tops
$150 set
Gauge clusters
$75
Thank you,
Adam B.
(716)428-1674
the shipping won't really be determined by the weight. I use a gentleman who owns a nearby business and regularly ships engines.. I drop them off and he crates an ships them for me.
I could get you a quote when I am there next, I just sold a complete ls1 and it is costing me $350 to ship it to Florida
That is to a commercial address with a fork lift so that makes is cheaper also
PM me or send me a text with your full address and I can get you a quote,
Thanks
Adam B.
Thanks
Adam B.
I removed the comp cam. After closely looking at it before selling it to a customer I noticed 1 lobe that wasn't happy... It had a little spot in it almost like a chip...
I wont sell it like that
Yes sir they are all 27 spline yokes
I will get you the measurements hopefully tomorrow.
All but the 3.5" are stock F-Body aluminum shafts.... I want to say the larger one came from a 9" car but I cant say forsure
Actually I do have 1 left... For my 408 but I would sell it for the right price.... Im a long ways from needing it
I have the reservoir as well I just removed it from the pump..
Pully is a gunmetal that wound up having a brownish tint too it.. Didn't clear the P/S pully tho
