I sure hope so!!!!!
It did run last night, well barely..... I was struggling to run, it was extremely lean..... After I got home last night I was looking the tune over and realized when I changed the map sensor in the base tune I used, it rescaled the base fuel map which caused it to be extremely lean down low..... I made some changes, we will see if it helped in a little while.....
Hope you find it quickly.
Me too!!!!! The trans is not that big of a deal, but it's just one more thing I really didn't want to do.....
Here it is on the bench.....
It was leaking fluid from the 3 bottom studs in the pump, the fluid was coming up the threads between the nuts and studs.....
At first I couldn't figure out how the fluid was getting to the studs until I looked at a pump gasket today, the holes for the bottom 3 mounting holes all intersect a passage or opening through a notch in the gasket..... I thing I can just change out the studs for bolts and not worry about it, the trans seemed to be working fine other then a small leak..... Here's what I am talking about with the gasket.....
I have been using this one, not sure its the best for the 56 series terminals...
http://crimpsupply.com/packard-delph...pack-tool.html
I'll get a pic of them today.....
Andrew
