93-97 camaro to truck headlight conversion
My only question is in the lighting FAQ where I saw the guys using these, they are mounted on an angle to match bumper line. On the silverado looks like they are straight on...so in other words, is this going to throw light on an angle if installed to follow the bumper line?
http://v6f-body.com/showthread.php?t=4325
The best alternative halogen bulb I've found is the 2011/2012 HIR. I use them in my truck that came with the same stupid 9005/6 bulbs and it's a huge improvement, all with the same longevity and wattage.
9012 replaces 9006
9011 & 9012 look similar to each other the same way that 9005 & 9006 look similar to each other. However the tabs are a little different. 9011 has higher lumen output than 9011. Just like 9005 has higher lumen output than 9006.
Also, the tabs on 9011 & 9012 are slightly different than 9005 & 9006 but they usually fit without trimming. If they need trimming, it is minor.
9005 & 9011 are intended for high beam
9006 & 9012 are intended for low beam.
9012 = low beam?
