Strange Engineering 12 Bolt with extras WILL SHIP
Category: Accessories
Price: $123
Location (State): NY
Item Condition: Used
LS Engine?: Fits LS Engine
*Strange Engineering 12Bolt Axle Housing
*Welded Axle Tubes
*Bearing Cap Studs
*"Big Ford" Bearing Ends
*Strange Engineering 33 Spline Axle Shafts
*Strange Engineering HD Steel Spool
*ARP 5/8"x2" Wheel Stud's
*Richmond 4.56 Gear Set
*Strange Engineering Ugraded HeavyDuty Pinion Yoke..Chromoly with HD Straps and Studs for 1350 Style U-Joints
*Strange Engineering GM 11" Drum Brake's
*LCA Relocation Brackets (Welded)
*Shock Adjustment Holes... Also Takes Coil Overs
*Ready too go, New Brakes, Pre-Made Brake Line's and more..
Also will come with
*Aftermarket Double Adjustable Tubular Torque Arm (Stock Length, Xmember or Trans Mounted)
*Strange Engineering Heavy Duty Torque Arm Bracket Assembly for the 12 Bolt
And lastly a Strange Engineering 3.5" Chromoly Drive Shaft...1350 Yoke with New U-Joints... Made to work with this rear end and stock F-Body length tailhousings..T56/4L60E/T5/700R 4 etc...
$2,250 obo for all thats mentioned.
I am in Buffalo NY but I can ship... However we will have to work out a deal for shipping costs...
THIRD GEN HOUSING LENGTH
(Roughly 1.5" Narrower PER SIDE than the standard 4th gen housing with NO TCS/ABS)
TTT Hell of a deal here.... The diff costs more new than the asking price of this full package.
Driveshaft and torque arm are made to make this a complete bolt in kit...
(716)-428-1674
Thanks,
Adam B.
(716)-428-1674
Thanks,
Adam B.
I will gladly wheel and deal with you if I still have it when you are in the market for one... It's been for sale for quite some time now at a reasonable price with not many bites so I wouldn't be surprised if I have it for a while longer.... The spool scares most people away
