2000 NBM M6 SS Turbo build
#41
Well the fans and gauges are wired. Hot and cold side buttoned up. Radiator adjusted and added a procharger radiator bracket.
Next on the list is the get my cbr alternator relocation kit and finish the wiring of my racetronix Hotwire kit.
#44
This is true! I just went through this myself putting my car back together!
500@10psi (01-12-2020)
#50
FWIW 4x4 crowd has seen the same thing, Most Jeeps use the Ford Taurus/Crown Vic fans and they are 2 speed and pull 50A on high. In line fuse holders are bad juju above 25A. You need #10 or #8 wire and good connectors for E-fans. Tap the feed power at wherever the Alternator wire meets to the battery..
#59
No problem guys if you have any questions just let me know.
Update- Local exhaust shops just do not want to try a 4" full exhaust and I kind of understand their concerns so I will be doing a bumper exit. I need to research some on removing the overflow tank and what all I need to do there then will use hurons 2 piece 4" so hopefully will have this thing dyno ready very soon.
Also I have a new PS pump and using the CBR alternator relo kit so no more tensioners. I am getting a horrible squeal when the car is idoling. Could this be the belt being too tight or loose?
