If I could get it to go 1.5x I would be very happy!
Originally Posted by assasinator
can you post your time sheet? id like to see all of the numbers. dyno sheet too? thanks.
I don't have a dyno sheet. I would assume it makes 700+rwhp from the mph.
Originally Posted by BADMOON
Car full weight? Even if it is should still be able to hit a 9.. Maybe if you leave harder or change converter..
Yes it has the heavier iron block and the heavy S60 rear, but lighter wheels/tires and no a/c or exhaust to the back so it should be just a little bit heavier then stock I'd say. I know the car will leave harder just need to work at it.
Was spinning when I was getting it to leave at higher rpm so I know it has power off the line to cut better 60's just have to plant the power. Going to try and loosen the rear shocks for the next visit to get the weight transferred to the rear better.
