alumastars, Custom Martin Smallwood Performance Cam, springs, etc..
Category: Accessories
Price: $1
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
Spec'ed for a 427" twin turbo setup. Specs are: 252/256 .750/.720 117+5. It's brand new, never used. I did slide it into the motor, but it never was fired. I have since changed the setup, so switching up the cam. This is a 3 bolt ls setup. $250
A pair of exhaust trim rings made of carbon fiber. Hole size looks to be around 4-3/4". Some minor scratches from laying around. $40.00
Weld Racing AlumaStar 2.0 Polished Wheels part # 788-510276. Excellent cond. never drilled for screws. comes with metal valve stems. Would look as good as new with a little polish.
15x10. 3" Backspacing. 4.75 bolt pattern. $600
Drysump oil pan. $150
injector bungs to setup dual injectors. $40
PAC 1324 springs, used. Only switching because I needed bigger. $180
Specifications
Part# PAC-1324
Dual Drag Race Spring - Bracket / High Lift applications
Mass (g) 152.0
Outer Spring I.D. (in) 1.175
Outer Spring O.D. (in) 1.625
Middle Spring I.D. (in) N/A
Inside Spring I.D. (in) 0.851
Install Load (LB) 275
Install Height (in) 2.000
Open Load (LB) 810
Open Height (in) 1.150
Coil Bind Max (in) 1.100
Lift Max (in) 0.850
