Cleaning Out The Car Hole
FS
CTS-V
Front subframe/engine cradle
Front Struts, springs & mounts $150/pair
Front control arms (uppers and lowers) $100/pair & $150/pair
Front Spindles $180/pair
Front Sway Bar with End Links $100
Rack & Pinion $275
CTS Base
Front Calipers $120/pair
Rear Calipers $80/pair
LS Parts
Valve Covers (3 pairs) $120/pair
241 Heads (1pair) $150
853 Heads (1 pair) $125
Set of 16 pushrods $35
Set of 16 Rocker arms $120
Truck Oil Pan $75
F-Body Parts
Coolant Reservoir $40
Wiper Fluid Reservoir $40
RS 3 Piece Spoiler $180
Rack & Pinion (brand new) $125
Center Console lids (93-02, one early model and one late model) $30 & $60
12 Disc Changer $60
T-Top chassis/door weather sttipping $60
T-Tops (one pIr tinted, one pair dot matrix) $60/each, $100/pair
Pewter Camaro power side mirrors $35/each, $60 pair
MAF Sensors (5) $35
Rear Calipers (one pair 93-97 & one pair 98-02) $50/pair & $80/pair
Carrier & Pinion Rearend bearing set (brand new) $80
Pewter Firebird Headlight assemblies (one pair)
Stock Camaro Grille & license plate bracket (98-02
Wiper Arm Regulator
MISC
3.91 gears
1inch fiberglass hood cowl (off of an older el camino)
Oil Cooler (heatsink style)
PS/AT Fluid Cooler (fin-style)
Theres more, ill update when i dig them out
CTS-V
Rack & Pinion $275
CTS Base
LS Parts
Truck Oil Pan $75
F-Body Parts
12 Disc Changer $60
MAF Sensors (5) $35
Wiper Arm Regulator
MISC
3.91 gears
includes ring, pinion and yoke
$150shipped
edit: GU9 is the only gm axle code that has a ratio of 3.91. Ring gear measures up to a 7.625" Dont know if that info helps, im sure it cant hurt.
