02 ls1 parts: ls6 intake, 241 heads, LS1/t56 harness, rockers, starter, etc.
Category: Accessories
Price: $1234
Location (State): TX
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I've got a good set of undamaged 241 ls1 heads complete with valves, and springs. they are dirty, but have no stripped bolt holes, no detonation, and are in good working order. Pulled from car with 125k miles. $200
I've also got a complete ls1/t56 fbody wiring harness, this is a complete harness that is off a bone stock car. nothing has been removed. The only issue with the harness is it was cut when the motor was being removed from car for some reason. it is the part of the harness that has just a few wires going down to the passenger side 02 sensor and trans i think. I can splice these wires back together and it'll be 100% again, or i can send it as is and you can do the same. very minor issue imo. it also has 1 02 extension harness on it, as well as complete battery cable harness from the car.sold
A set of 16 oem rocker arms, with bolts, and pedestals. will include stock 7.4" push rods also. all in good shape, no needle bearings failing. would make a perfect candidate to have some truions installed into these. $75
An oem starter from this same engine. dirty, but was in working order when removed. complete with bolts, and heat shield.$60
A bare ls1 fbody power steering pump. i was going to send it off to turn one to have them rebuild it for race use as a backup, but never got around to it. Sold
I've got a loaded ls6 intake manifold off this same engine. complete with all bolts, throttle body, hoses, pcv, valve, injectors, and fuel rail, and throttle cable bracker. only thing it doesn't have are the tps/iac and map sensors. sold
ive got a complete AC compressor mounting bracket with both tensioner pulley and idler. $50
A set of 16 oem Lifters with trays. no damage. $50
easier contact is text/call 210-551-2166
all pricing is plus shipping!
