These parts came out off an 05 Escalade, everything has been cleaned up and ready to install
intake
MAP sensor
purge valve
fuel rails and injectors
drive by wire throttle body
gaskets and bolts
SOLD
oil pan with drain plug
oil level sensor
oil baffle
windage tray and pick up tube
gasket and bolts
SOLD
lifters, trays, and bolts
SOLD
pushrods
SOLD
78mm drive by cable throttle body
TPS and IAC sensors
SOLD
intake
MAP sensor
purge valve
gaskets and bolts
SOLD
oil level sensor
oil baffle
gasket and bolts
SOLD
SOLD
pushrods
SOLD
TPS and IAC sensors
SOLD
