Did I crossover to the dark side? (Square port porn inside)
Old 09-01-2017, 03:31 PM
  #81
KCS
KCS's Avatar
Originally Posted by blk00ss
Lmao that's what was so funny to me. He couldn't keep his **** straight for more than 2 minutes. Had different stips every time he posted.
Old 09-01-2017, 03:34 PM
  #82
cdubbzz's Avatar
I'm assuming you went with medium bore ls7's? What castings? Sticking with the ol 408? Good luck on the build! I honestly don't know if I'll even put mine on the dyno. The powerglide showed such a loss on my old setup that I don't want my feelings hurt lmao. And it will never have a NA convertor so I'll never know the true potentional of it on motor at the track.
408 is sold..picked up one of the last ERL sleeved alum 5.3's...heads are FRH prepped Brodix BR7's with port matched CID. I plan on having this combo on an engine dyno for the same reason. The track tells all!
Old 09-01-2017, 07:36 PM
  #83
blk00ss's Avatar
Originally Posted by KCS
Yeah I'm. It a fan of it myself. Just like the way it smells
Old 09-01-2017, 07:38 PM
  #84
blk00ss's Avatar
That's awesome. Always wanted one of their blocks. Did you happen to get a super deck with the 6 bolt option?
I was always really impressed with your 408 results. I'm sure the new build will be a monster as well.
Old 09-07-2017, 05:53 PM
  #85
blk00ss's Avatar
Got my Trend 7/16" .165" wall pushrods in. These things are monsters! But there's still plenty of clearance in the heads. Almost wonder if it would take 1/2" ones...
Compared to a stock PR lol
Just waiting on my MLX headgaskets... I have a brand new set of cometic MLS here. But I want to try the newer MLX ones. They're supposedly being built for me and drop shipping from cometic. If it takes too much longer it's going together with what I have.
Something else I just ran into is something is scraping inside the oil pan when I rotate the crank. I'm running the Moroso steel oil pan that claims it clears 4.125" stroke. And mine is just a 4.1". Going to have to investigate some more. Try and pin point exactly where it's hitting
Old 09-08-2017, 05:08 PM
  #86
blk00ss's Avatar
Did some more PTV measuring today with the new pushrods. And wanted to double check the valves sit in the valve pockets ok since the pistons weren't ls7 specific valve pockets. Looks like roughly .225" of clearance on the intake and .230" on the exhaust.
Looks like I got plenty of clearance around the valve pockets.
Here's the intake clay
And the exhaust
Old 09-09-2017, 04:07 PM
  #87
Jimbo1367's Avatar
Wow. You have some hairy wrists. LOL
Old 09-09-2017, 04:49 PM
  #88
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Wow you must be bored,
Outstanding EQ as well BTW.
LOL
Old 09-10-2017, 12:26 AM
  #89
blk00ss's Avatar
No wonder no one post on here anymore.
Old 09-10-2017, 12:35 AM
  #90
Exactly!
OP is documenting an awesome build and providing valuable info regarding
PTV Clearance with a Huge LLSR, among other things.
And Jealous Haters talking about Toasters & Wrist Hair?? WT..?
Old 09-10-2017, 12:49 AM
  #91
Blk00SS
I Know you don't believe in Dynos, Engine or Chassis.
However I believe your Engine would make ~850 @ the Crank NA.
I am guessing each stage would add 150-250+ more,
Or + 300-500+ More.
1150~1400 Total.
Insane!
Looking forward to your Track results, hopefully some 1/4s as Well as 1/8s.
One of the 3-4 Best Threads on Tech currently IMO.
PS I don't throw #s around , I actually put some thought into them
LOL.
Old 09-10-2017, 01:47 AM
  #92
blk00ss's Avatar
I'm sure I will get it on the dyno, I just know it won't be impressive. I went from right at 600rwhp with the old combo through the 6 speed. To 522 through the glide lmao. But actually trapped a hair higher. The direct port is staged for 250 and 200 right now lol. And only 1/8th miles passes for us down here.
Old 09-14-2017, 02:29 AM
  #93
blk00ss's Avatar
Messed around with it some more today. Got one head on lol. Just taking my time trying to clean out all of the head bolt holes as well as I can. And cleaning up the deck surface as well as possible too. The extra studs that are screwed into the bottom of the head are really aggravating to get to with a torque wrench. Especially with no help. Really a two man job lol.
New cometic 4.200" bore with .040" thickness.
These Crower stainless rocker arms are very impressive. Superb fit and finish. Even supplied with Crower branded ARP stand bolts.
First set of heads I've ever had that didn't have the intake rocker bolt hole go through to the intake port. Nice surprise. Although the valve cover bolt hole does go through to it lol
And just a fancy shot of adjust the valve lash...
Old 09-14-2017, 07:29 AM
  #94
KCS
KCS's Avatar
Those inner studs are a PITD. I use an extension to get on them with a torque wrench.
Old 09-14-2017, 08:15 AM
  #95
big hammer's Avatar
Lol that's what I used for pushrods, except Manleys. They ended up being a common BBC length so I got lucky. They fit in the mast heads pretty easy
Old 09-14-2017, 08:17 AM
  #96
big hammer's Avatar
Originally Posted by NAVYBLUE210
Blk00SS
Or + 300-500+ More.
1150~1400 Total.
Insane!
LOL.
Yeah too bad. This combo in a 6 speed would make some wicked numbers.
But he's a *barf* track guy :p
Old 09-14-2017, 09:49 AM
  #97
blk00ss's Avatar
Yup I use a proto extension deal like that. And still had to grind it down to where it's only about a 1/4" thick so it would fit between the stud and the raised hump right below that stud inside the valley. Next time I have it to a machine shop I want to get that stud ground off.
Old 09-14-2017, 09:53 AM
  #98
blk00ss's Avatar
LOL. More street than youv ever thought of been sweety
Old 09-14-2017, 02:52 PM
  #99
Rise of the Phoenix's Avatar
Nice updates. This thing is going to be a real monster.
Old 09-15-2017, 09:30 AM
  #100
Zmg00camaross's Avatar
Going to make some steam!
Quick Reply: Did I crossover to the dark side? (Square port porn inside)
