PS pump repair in PICS !
rebuilding the Saginaw (Type 2) TC PS pump !! The top secret rebuild info no one wants you to know !!
Finally got her dun .....here is what ya need
seal kit...I used a edelmann part.....or you can use GM 26053277
ring kit ...GM 26046606
small screw driver.....sharpened
punch... 3/32
press.... i used the larger harbor freight one ( 2 tons? )
22 mm wrench or socket
3/8 allen
pick and hook set
rubber mallet
assembly lube...I used lucas...green n sticky
vasaline....use it on the seals
much kudos to PSC Motorsports in Azle TX for allowing me to pick their brains to find out how to do this as I know of no manual available for repair ( and neither did PSC ) , they do all steering systems for any car or truck but specialize in 4x4 stuff...hit em up if ya need em
follow along......
punch... 3/32
3/8 allen
pick and hook set
rubber mallet
follow along......
Last edited by sjsingle1; 11-12-2017 at 02:56 AM. Reason: corrected to Saginaw (Type 2) and capitalized Saginaw to properly honor the fine people of the namesake city in Michigan.
Vroom! (11-25-2021)
the big O ring goes in the housing....smaller of the big O rings goes in the outer cover
small black for the reservoir....small green on the pressure valve nut
seal...self explanatory
first step....remove resevoir....to do that ya gotta get the clips off
I used a hook from a pick and hook tool kit
lift up on the inner tab and punch the other side of the edge of the clip with a screwdriver to push the clip off...if ya got a friend to help MUCH easier
pull off the reservoir and notice how bad the O ring is ....leak city !!!
next step ...get the ring retainer out of the back cover
there is a small hole on the bottom of the pump ...use the 3/32 punch to dislodge it out of the recess
the back cover does not just pop off....use a rubber mallet to hit the the end of the shaft to push the cover out and off
not to hard or you will send it across the room !
with the cover and top plate out of the way you can see the rotor...vanes and outer rotor housing
notice the 2 diamonds on the outer housing.....important for later reassembly ....diamonds go up toward you
outer housing removed
notice the alignment pin(s)
see the diamond on the rotor....up toward you for reassmbly
