dual pump wiring diy wiring
Old 11-12-2017, 01:34 AM
TPI TERROR's Avatar
Default dual pump wiring diy wiring
as many ls swappers have a basic understanding of wiring and sodering i wanted to attempt to build my own wiring harness for duals currently running a single, i have seen several people run the fuel pump relay differently switching terminals 85 and 86.
from my ls1 swap notes this is how i usually wire up a relay for fuel and iirc this is how i ran my current single fuel pump
terminal 85 connect to pcm red 9
terminal 30 connect to fuel pump input
terminal 86 connect to ground
terminal 87 connect to switched 12v power supply with fuse
for the dual would this be correct ? terminal numbers are inside image . contant 12v will have 20 a fuse , plan on running 12 or 10 gaueg wiring and good relays. battery mounted out back
Old 11-12-2017, 10:34 AM
Crf450r420's Avatar
Most ECU controls are grounds, so you will probably need to supply positive to 86 instead.
Old 11-13-2017, 12:59 AM
brandon6.0's Avatar
I wanna say the fuel pump output is 12v supply. Everything else is usually grounded from the pcm.
Old 11-13-2017, 06:31 AM
Restricted User
JoeNova's Avatar
Fuel pump is 12v supply from PCM, not ground.
Old 11-13-2017, 09:45 AM
Crf450r420's Avatar
Now that you guys say it. I remember wiring a 12 volt to activate the stock relay. Sorry, that was almost 2 years ago I was working on that last.
Quick Reply: dual pump wiring diy wiring
