JE "Nascar" Pistons, looking for Info
Specs are:
Bore: 4.000
.923 floating wrist pins
Flat Top
Comp Height: 1.314
Piston Weight: 481
With a 6.125 Rod in my LQ4 with LS9 gaskets and L92 heads the summit racing compression ratio calculator puts my CR is right around 10:5:1 a little high for a boosted build but I plan to temper it with E85 anyway, or quality 93 octane from time to time when E85 isn't accessible.
DG
.923” is an odd ball wrist pin. Which by the time you re bush small ends of rods or hone the pistons out .004” and purchase pins. They’re just no longer a deal
From Yates site...
Thanks,
DG
Thanks,
DG
Even those I've seen split in the center from ragged edge tunes and continuous detonation
Just my .02
I agree with you, I don't need them shattering like glass. Just looking at the weight alone I should have figured they wouldn't be great for FI
DG
