My 99 Camaro build
Old 10-28-2017, 09:33 AM
  #41
CaptainSavage's Avatar
Originally Posted by Jtm2085
The cage looks good. Info on depowering the steering rack?
Thanks! Here’s the info I came across
https://camaroforums.com/forum/93-02...-pinion-72815/
https://www.flyinmiata.com/tech/depower.php?x=1
I know it’s for a Miata, but it works the same for our cars.
After reading those threads I tackled it. It was really easy, I didn’t use a torch to remove the valve. I used a 3” cut off wheel and that worked perfectly. It’s a soft metal.
Old 11-11-2017, 04:32 PM
  #42
So today, I replaced, both window motors and regulators. Wired up new switches and deleted all of the extra wiring that was in the doors. Trimmed and made new aluminum door panels. They look crappy, but they still have to protective plastic on them.
Old 11-24-2017, 11:09 AM
  #43
Kcutty85's Avatar
Very cool work so far , any updates?
Old 11-28-2017, 08:11 AM
  #44
Thanks! Not yet, right now I’m working on rewiring the whole car. Im thinking about buying a hotrod wiring kit for just the essentials (lights, horn, wipers, etc). Trying to strip and rewire the factory harness to work without the BCM is a pain.
Old 11-28-2017, 08:53 AM
  #45
Crf450r420's Avatar
Factory harness is far from minimal, so that might be a time saver.
Old 11-28-2017, 02:39 PM
  #46
You got that right. I bought a universal wire kit for the power windows. It works great and was easy to use. Plus it got rid of what feels like 5lbs of wire. I think I might just go that route. Save me the headache and weight. Haha
Old 11-28-2017, 06:26 PM
  #47
Crf450r420's Avatar
Plus, you get fresh wire over some 15+something year old wires.
Old 12-11-2017, 11:19 AM
  #48
Still at it, New Ac Delco water pump, knock sensors and gaskets for the intake. Still figuring out a harness to use for the chassis. I found a few on Amazon, that received good reviews. I may pull the trigger on one of those after the holidays. But here’s some pics of the LQ4. I’ll figure out alternator placement when I figure out what turbo manifold I’m going to use.
Old 02-06-2018, 01:57 PM
  #49
Just installed Comp Cams rocker Trunnions and Tick Performance Pushrods. Now that the engine is near completion. I have to get it in the car to mock up the placement of the turbos, manifolds, and piping. Anyone have any recommendations on a K member that will give the most amount of space for twin turbos? I was thinking about going with MWC's turbo K member.
Old 02-20-2018, 11:15 AM
  #50
K-members on order with Midwest Chassis. Pics of the kmember and install to come. 👍👍
Old 02-27-2018, 10:49 AM
  #51
Painted the engine bay with VHT chassis paint. It turned out really good. As soon as the K-Member arrives it’ll be ready to accept the engine.
Old 03-02-2018, 09:42 PM
  #52
Noob44's Avatar
Cant believe how good this is turning out! Keep up the great work! Watching like a hawk
Old 03-02-2018, 11:11 PM
  #53
Thank you, I appreciate the positive feedback.
Old 03-05-2018, 07:05 PM
  #54
Ordering some more go fast bits! Updates soon!
Old 03-14-2018, 09:26 PM
  #55
mean99ss's Avatar
looking very awesome, can't wait to see more!
Old 03-16-2018, 03:01 PM
  #56
Intercooler just arrived from VSracing.
Just waiting on a few more items to start mocking things up
Old 03-19-2018, 03:10 PM
  #57
These look so good up and forward, but i don’t think they’re going to fit. May have to swap them to down and forward
Old 03-21-2018, 09:04 PM
  #58
98vertss's Avatar
Can't wait to see that power plant under the hood
Old 07-02-2018, 08:16 PM
  #59
It’s here, time to start moving forward!!!!
Old 07-07-2018, 01:57 PM
  #60
Kmember fits great! Got the engine in. Only problem I’m running into at the moment are these turbo headers. They won’t work up and forward due to the strut towers and they won’t work down and forward because they block the steering shaft. Anyone have any recommendations on a pair of headers that fit these cars or should I use reversed truck manifolds? Which I have.
Quick Reply: My 99 Camaro build
