Did I crossover to the dark side? (Square port porn inside)
Old 02-14-2018, 11:32 AM
  #241
Received 3,155 Likes on 2,462 Posts
Originally Posted by big hammer
You actually get to run the 1/8 in the 1/4!
Yeah! Just back off 1/2 way down if you're hard-headed about it...
Old 02-14-2018, 12:23 PM
  #242
sillysspeed's Avatar
This car is gonna be a beast! I like that bottle mount alot
Side note : I switched over to square port also
Old 02-14-2018, 12:42 PM
  #243
blk00ss's Avatar
If I run the 1/4 it makes me full gay. As long as I stick the the 1/8th I’m only half gay. Good talk.
  #244
blk00ss's Avatar
Was just reading back. Holy **** that wiring panel looks good!
Thanks man. It’s a racewire solutions panel.
Old 02-14-2018, 12:44 PM
  #245
blk00ss's Avatar
I hope they’re of the 7th series of LS heads and not the 3rd
Old 02-17-2018, 02:08 PM
  #246
blk00ss's Avatar
Everyone loves pictures right lol.
Pro bracket radials mounted
Street car life��
Random shot
Old 02-17-2018, 06:35 PM
  #247
Jtm2085's Avatar
Looking good. Now hurry up and finish so I can use the shop!
Old 02-24-2018, 10:27 PM
  #248
blk00ss's Avatar
Rear wheels and tires back on. Did a little clearance go on the calipers while they were off. They were just barely clearing. Wasn’t comfortable with it.
Got some new blacked out factory style headlights. Couldn’t handle the projectors. Also VHT’d the rear lights, 3rd brake light, side markers, and turn signals.
Got the bottle mount set for good. I still want t change my feed line setup a little. Want to do a 1/4 turn valve and 4” gauge by me.
And got a coolant overflow tank mounted.
Only things I have left is adding a headlight pigtail on one side and a turn signal bulb socket as well. Not sure what happened to them. Gotta get the windows tinted as well. Can’t handle the fishbowl look at me clear glass lol. And still trying to find a parachute mount that is the right size for what I have already. And then some tuning and start making hits.
Old 02-25-2018, 01:31 PM
  #249
big hammer's Avatar
Your nitrous bottle is fake
Old 02-26-2018, 12:02 AM
  #250
blk00ss's Avatar
#notmypresident
Old 02-26-2018, 12:28 PM
  #251
KW Baraka's Avatar
Originally Posted by blk00ss
#notmypresident
LOL!!!
KW
Old 03-01-2018, 04:01 AM
  #252
That_One_Person's Avatar
Surprised you're still rockin' the big single out of a Y. Nice progress can't wait to see it run.
Old 03-01-2018, 11:33 AM
  #253
blk00ss's Avatar
Yeah I know lol. I don’t like how the Texas speed x pipe is made and I think the 3” would still be a restriction at my power level. I want to fabricate a 3.5” x pipe. Or probably just end up with some vibrant mufflers off the collectors lol
Old 03-01-2018, 12:58 PM
  #254
Jtm2085's Avatar
What's wrong with the tsp x pipe?
Old 03-19-2018, 12:00 AM
  #255
blk00ss's Avatar
Well I had a little delay. Had a bad Holley engine harness that wouldn’t fire the coils or injectors sometimes and if you moved the harness a certain way with the car running it would kill it. So I had to tear the dash back off, intake off, starter off, etc to swap out the harness. Got it fired up this morning before work and had Holley self learning the idle. Within seconds it was idling on its on. So here’s a short clip of it idling through the 4” dynomax muffler.
Parachute mount will be here tomorrow. So got to get that on, need to run the valves after that initial warm up today, change oil, do a little more tuning, tidy up some things like getting the dash back in, cleaning up some wiring, wash it, then hit the dyno or track really soon.
Old 03-19-2018, 05:26 AM
  #256
Darth_V8r's Avatar
Sounds great. You can hear each cylinder pop
Old 03-19-2018, 07:46 AM
  #257
big hammer's Avatar
https://youtu.be/zKUGxTaPpFw
How do you like that engine controller setup? Does it work on 24x? My engine is maxing out the stock ECU now
Old 03-19-2018, 09:28 AM
  #258
blk00ss's Avatar
It’s so simple I can do it lol. So simple yet one of the fastest guys in the world uses it. Stevie Jackson. It’s awesome and affordable. You can be in it for your car for less than $1800.
Old 03-19-2018, 01:52 PM
  #259
blk00ss's Avatar
Parachute mount done
Old 03-19-2018, 01:57 PM
  #260
Tuskyz28's Avatar
Badass brother!!
Quick Reply: Did I crossover to the dark side? (Square port porn inside)
