Giant LS3 Intake Manifold Dyno Shootout!
#101
One thing I find interesting is how much variation there is in the peak power RPM. Using the FAST manifolds as an example, you see a change in peak power of 200RPM for each of the shorter runners, just as you would expect would happen.
However, when these guys tested the cathedral manifolds, there there was only a 200RPM difference among all 20 manifolds, yet the runner lengths varied from 5 to 12".
Obviously in any test, you could see some other aspect of the engine as a limiting factor. In those cases it may have been the camshaft, cylinder heads, other.
If none of the intakes are exceeding a certain power level or rpm....then it's safe to say some of those intakes are not the limiting factor.
As said, we'd all love to see these tests in a huge range of engines....not so easy to find someone to foot the bill for doing so
#102
The part that sticks out to me is not just how consistent the cathedral manifolds peaked, but how high they peaked compared to the rectangle port manifolds. On one hand, you have the OEM LS3 peak at 6500 RPM, which seems pretty typical, but on the other, you have the OEM LS1 manifold that made peak power at 6900 RPM and the OEM LS6 that made peak power at 7000 RPM. That seems unusually high to me. I would think if the cathedral port tests were limited, they would not peak so high. If the rectangle port tests were limited, you would not see such variation.
#103
I do find it strange they do peak so high.
I've had a variety of intakes, heads and cams on my cathedral over the years ( all with boost ), and pretty much none have ever been happy over 7k.
Yes I could hang on and ring the life out of it, but beyond 6700rpm or so you just knew it didnt want to be there. Only time I'd hang on much longer would be through the traps in either 4th or 5th depending whether 1/4 or longer distance event ( 5th would see 200mph around 6700rpm )
Even logging accel-g it's quite apparent where in the rpm range it slows down...and every time on mine it is before 7000rpm
I know if I could find a combo where it would make real strong power to 7-7300rpm it would help me a lot, even more so as I've changed to a Magnum and 5th is now shorter which will mean 200mph will require more rpms. I've bought one of the cheap crap Sniper intakes now to see if that might help me as mid range losses are of little concern and might actually be a benefit in terms of traction.
Interesting to note both the cathedral test and LS3 test use a camshaft with the same timings/lift. Although other dyno videos recently have proven all this square port/cathedral port camshaft is largely nonsense as there is negligible difference if you test them
LS3 " as many of these intakes were not designed for our mild cam-only LS3 crate motor (specs on our COMP 54-496-11 hydraulic roller measure 231/247 degrees at .050 and .617/.624-inch lift with a 113 LSA)"
Cathedral " The Comp 469 cam offered a 0.617/0.624-inch lift split, a 231/247-degree duration split and 113-degree LSA. Topping the 6.0L was a set of AFR LSX 230 V2 heads"
So clearly the cylinder heads could be the big factor here with the LS3 listed as just a crate motor...so presume stock heads ? Springs, rockers ?
#105
I'm critical of that cam test too. I think there was a flawed premise that the exhaust duration was the factor in a rectangle port camshaft. I believe the intake duration is the more influential factor. Since the big intake valve offers much more curtain area at each respective lift point, you can reduce overlap and the IVC point to make about the same power, but with considerable increases in low end power and driveability. Instead of going from a 239 to 247 exhaust duration, they should have gone down from a 231 intake duration to a 22x duration.
Or maybe Diet Coke is right. Maybe someone is pushing that 231/247 cam.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#106
What did you use to log acceleration g's? I've been thinking of trying that
#107
I can log on the VBox as a standalone but I also log on my ecu ( Syvecs ) which receives GPS/Accelerometer data from my Plex SDM-500 dash unit.
As said, I can easily rev to beyond 7000rpm...but you just know it isnt happy up there. Highest I've seen was just shy of 7500rpm but that was just last year as I'd broken 5th gear and getting highest trap for 1/2m even for a rwd car would have been easy just by hanging on in 4th.
Except I didnt want to hold 4th for the entire duration so was just trying to judge how long to hold in 4th but still win.....not easy to judge at all ! Ended up missing it by 1-2mph as I left it a little too late before going full throttle in 4th. But at the same time, didnt want to risk taking it on to 8k although it probably would have been fine.
Hopefully in a few weeks I can report on how the Holley Sniper changes anything up top.
#108
These tests you have to take with a grain of salt. One wouldn't want to spec the same cam for a long runner fast vs a short runner fast or mid runner fast.
Also the loss of engine tq doesn't always mean the loss of wheel tq when you can pull more gear for the more rpm. They really do us all a injustice by not running out past peak hp rpm wise.
If they optimize the cam and tune for each manifold, people scream that the results are invalid because too many variables were changed.
If they keep everything the same and only change the manifold, people scream that the results are invalid because the setup wasn't optimized for the manifold design.
#109
None of these manifolds are a one size fits all. The test does kinda tell you the operating range of these intakes but we would know more if they rung em out to 7500.
#113
Received 1,838 Likes
#115
http://www.superchevy.com/how-to/eng...t-intake-test/
I had the same thought and even did some calcultions. The diameter of the ITB is approx the same diameter of the choke of a stock ls3 Head. It is smaller than the choke on an ls7. I agree they need to be bigger.
Then I found the test in the link and idk what to think anymore.
#117
#120
