z28 roller
BMR Subframe connectors
BMR Driveshaft loop
BMR Panhard Rod
Wolfe Rear control arms
Wolfe Sway bar
Wolfe Torque arm
Wolfe 6pt cage with swing outs Also have the front half to convert the cage to a 10pt
Battery box relocated to the rear with kill switch
Moser 9in with 3.55's spool and 33 spline axles
Speed Inc fuel tank
Sparco stering wheel
Harwood ss pin-on hood.
Qa1 R coil overs in front
Qa1 R adjustable rear shocks
Strange front and rear drag brakes
Bogart D10's
Hoosier front runners and 28.10 rear slicks
Billingsley manual master with line lock
TSP smoked lid
Over flow bottle
B&M ratchit shifter
All the wolfe stuff is chromoly. The brake lines need to be hooked up to the master. The master also needs to be hooked to the brake peddle. The body is in nice shap the paint is a little ruff but not to bad. I do not have a seat for the car i was going to put one race seat in it. All the work as done by CJ at RMP in lewisville. The car has been gutted. With motor and tranny the car should weight in around 2900 or so. I can e-mail pics so pm me your e-mai address.
http://www.dfwstangs.net/forums/showthread.php?t=206217 pics
6500
Thanks,
Josh
Pm sent
you have a PM
