GM Part Lookup
Old Aug 9, 2005 | 03:45 PM
SSmonte's Avatar
Default GM Part Lookup
Does anyone work in the GM parts department? I need some parts looked up for my future swap but the local dealer sucks and GMpartsdirect needs a VIN to look up the parts.
If you can, shoot me a PM and I'll let you know what I need. It'll help a whole lot to get this swap moving faster.
Thanks
Nick
'88SS
Old Aug 9, 2005 | 05:53 PM
ROCNDAV's Avatar
I can help you a bit with 4th gen fbody and C5 parts.
You could also try searching the forums. There are already some good threads with a lot of part numbers listed.
You can also pick up Parts list on ebay pretty cheap. Thats what I did.
Old Aug 9, 2005 | 09:56 PM
SSmonte's Avatar
I need the following part numbers for a 99-02 F body...
Throttle cable
LS1 Auto flexplate
Starter
Rubber Engine mounts, both sides
TPS
IAC
Throttle cable bracket that bolts to the intake.
If anyone has these PN or knows where I can find them, let me know. I figure the only two weird ones will be the rubber motor mounts and the throttle bracket.
Thanks
Nick
Old Aug 10, 2005 | 05:54 PM
ROCNDAV's Avatar
Sorry about the delay. This was pretty cool, cuz I actually need most of these parts too
1. Throttle cable:
98-99 Cable, LS1 (EXEC NW9) 12565559
98-99 Cable, LS1 (NW9) 12552267
00-02 Cable, LS1 (EXEC NW9) 12565560
00-02 Cable, LS1 (NW9) 12563651
NW9 = Traction control
2. Flexplate: 12553054
3. Starter:
98-01: 10455385
02: 10465547
starter bolts:
Outboard bolt (M10x1.5x113):
98: 12558858
99-02 (zinc): 12561387
Inboard bolt: (M10x1.5x46):
98: 12555160
99-02 (zinc): 12561848
4. Engine Mount:
98-99 (qty 2 required) 22174968
00-02 (qty 2 required) 22179268
5. TPS Kit (includs TPS and oring) : 17123582
6. IAC kit (includs IAC and oring) : 17113391
7. Throttle cable bracket : 12552278
there is also another throttle cable bracket which gets mounted on the rear drivers side fule rail stud:
8.Bracket: 12552865
Old Aug 10, 2005 | 06:08 PM
ROCNDAV's Avatar
oh by the way, I might have some rubber mounts available, once I get my polys next week.
Be sure to check out SPDC.com when ordering these parts, they are a sponsor.
http://www.sdpc2000.com/cart.asp?act...tart&catid=873
Enter the GM part numbers in their search box.
HTH
David
