Help me analyze my old 480rwhp 231/237, TEA 1.5 5.3/FAST90/QTP HVMC setup
So, gasket choice was not a factor in determining compression. ---
This was done last Spring. I sold the car, but never analyzed why the setup did what it did. I simply bought things that seemed to making power and put them on the car. I seriously never computed the compression or even looked at the low to mid lift values of the heads. I just wanted to know that PTV clearance was fine and I knew that +300 @ .600 on heads was good (yes, I'm serious, Southie shows his ***).
Now, I'm learning more about things like compression, chamber volume, cam lobe profile design (just your basic .006-.005 understanding of what a soft or hard lobe is like). Still grasping to learn valve event values though.
I'm beginning to think that not milling the heads any (besides PTV concerns) helped quench (still grasping to learn quench values, I understand what the quench area does, but don't know much about range).
2002 SS, M6
Heads: TEA Stage 1.5 5.3L Heads, unmilled (approx 63cc), MLS gaskets, approx 10.7:1 compression. 2.02 intake valve, stock exhaust valve.
.100 71.8/61.4
.200 139.9/122.5
.300 203.4/186.1
.400 247.2/236/3
.500 283.7/255
.550 297.8/258.1
.600 309.6/260.8
Cam: TSP 231/237 .598/.595 112 Lunati Lobes check in at (.006-.050= 58/62)
Went from:
A)390rwhp @ 6250/ 360rwtq @ 5000: cam only
B)425rwhp @ 6250/ 387rwtq @ 5000: Heads, same cam, same bolt-ons
C)480rwhp @ 6500/ 418rwtq @ 4750: Same heads, cam, new bolt-ons (470rwhp cutouts closed)
A) TSP231/237, Lid, Stock LS6 intake, Ported TB, UD pulley,SLP LT's, 3" Custom X-pipe Spec III, HD DS, 4.11 9" rear.
B) Same Cam, TEA Stage 1.5 5.3L heads, Same bolt-ons, same rear
C) Same Cam & Heads, 85mm Lid, 85mm MAF, FAST LSX(outof the box) 90/90, QTP HVMC LT's, QTP Dual Qtec ORY, SLP 2OTL catback, *Degreed the cam, same rear, *further tuning.
* 460rwhp/403rwtq before degree and further tuning
What do you all get from this info?
At the very least, I'm documenting what happened for reference sake, as I never compiled all the info into one thread.
I did have to get a different daily driver though. Keeping that car as my DD was not an option (and it had nothing to do with drivability).
I know! I know!
Hoping to get some tech talk started though.
480 is awesome through a 9"
I hope to hit high numbers when I get my heads and 90/90 only to lose some through a 9 "
The car left my possesion, making 460/403.
The new owner at the time (I don't know if he still has the car by now) is a partner at a very reputable GM shop (a sponsor on this site) who has full access to a dyno and tuning, and of course, the shop and knowhow.
I spoke with him 2 months after the sale and he told me that not only did he replicate the 460/403 pull with similar numbers (in a different state), but that he had pulled the cam, installed it degreed, changed the plugs and tuned the car further to get 480rwhp cutouts open, 470rwhp cutouts closed. He DID NOT however, give me a tq. figure. I extrapollated a figure and in included it in this thread, but it's a conservative figure, so I thought no harm done, it's easier to look at a number than some question marks.
So, all HP figures and TQ figures are legit, save for the final tq number.
As for the cam being installed dot to dot, yes it was. My buddy installed it, I was next to him. It was as close as we could get to a visual dead on.
I never got to race the final version
. Cam only; 12.1 @ 118mph 1.9, full weight, Drag radials, cool, dry winter air.
425rwhp Heads/Cam setup; 11.8 @ 118mph 1.79, full wieght, Drag Radials, dog humid summer w/ T-storms looming and a Posi kicking its final hoorahs.
I was hoping for low 11s @ 125mph on the 460rwhp setup with the repaired rear end in good air.
Also, all times shown on stock suspension.
Was that with 17inch wheels on the front and back?
Do you remember where how you went thru the traps, 3rd or 4th at what RPM?
Awesome times man.
Thanks,
Awesome times man.
Thanks,
Cam-only was with the 9". I would leave @ 5000rpm. I forget if I would cross the traps in 4th or 5th.
My shift light would come on @ 6750, I would shift @ 6800. Limiter was set at 6900. Cam would hold peak for a good while.
