help just installed new clutch etc and having shifting problems
might try to vacuum bleed it
In regards to the hard shifting/getting into gear = hydraulics problem. If you are running the stock master cylinder, you might need to "drill mod" it. My McLeod adjustable master was only bench bled, drill modded, and slightly adjusted for the throw and it is perfect. What the problem is, there is not enough fluid being pushed to fully disengage the clutch. The drill mod should help.
Good luck
Andy
I bleed by having a buddy pump the pedal three times, hold, i crack the bleeder for a second, tighten, release pedal?
Thanks
Andy
This works best!! If you have access to air, I like to use a cap on the resevior that has a small hole in it and pressure bleed the MC. Most LS1 F-bodys have this cap. Pull the rubber out in the inside. You can apply a soft air supply and have someone pump the brakes slowly with the bleeder screw open. Tighten the bleeder screw and apply just a light amount of air pressure, with someone pumping the clutch again. Then just pump the clutch fast. You should have a good pedal now. Replace the rubber.
