L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old Feb 20, 2007 | 04:49 PM
WKMCD's Avatar
Originally Posted by edcmat-l1
One of the issues we're dealing with. Cant get enough timing in this thing before the KR kicks in.
Thats interesting. And with the exception of the L92 responding to a higher DCR, what you stated is almost exactly what I told WKMCD. Back the comp just enough to allow more ignition timing.
Again one of the exact subjects we've dicussed. Get the exhaust #s up. not header tube size specifically, but flow numbers.
Again, interesting. This is what we're after. Less overlap. one of the things "I" specified. I guess I'm a pretty good guesser...I've stated the same opinions/concerns/questions to some of the folks I collaborate with. And have gotten some of the same feedback.
We had the cam ground with no advance, so I have the option of moving it around a few degrees.
Maybe I can get me a cool gig like a custom cam specialist?
We're probably about 5 degrees short of timing to make better numbers because of the DCR. It won't take any more than 25 degrees of timing before KR. The new configuraton will drop the compression to 11.5:1
Old Feb 20, 2007 | 10:16 PM
KAOS's Avatar
i would look into a diff cam. mizfit motorsports made mad numbers with a 416, i mean your only talking 14 more cubes and a lot more power. check into it and i think this will rock. its good to see people putting together diff. combos with the l92 stuff. good luck
Old Feb 20, 2007 | 10:46 PM
DrkPhx's Avatar
Why the dip for both hp and tq at 4000 rpms? The hp curve does taper off pretty fast after peak (if you revved it to 7000 rpms).
Old Feb 20, 2007 | 11:19 PM
White_Hawk's Avatar
Originally Posted by Patrick G
I think with the large intake port, the airspeed must be pretty slow. This might explain why they're so overlap sensitive. This does not mean you have to run a wide LSA cam or a narrow one, you just have to hit the valve events that fit the critical criteria (IVC and overlap).
Patrick, what do you think about the IVO? I have been talking to some old school cam guys and they have been telling me to open the intake as late as I can with these heads. They say you need to create a little "suction" to get the air moving because it is a lazy port. Running higher LSA's also has the effect of opening the intake later too.
-Geoff
Old Feb 21, 2007 | 03:10 AM
ringram's Avatar
Id say LG has their cam heading in the right direction out of everyone so far.
What would be really great is for a mag or someone to do around 10 cams of varying specs and see which one was best. Then its apples to apples. Im sure it will happen...
Old Feb 21, 2007 | 05:36 AM
WKMCD's Avatar
This from Richard at WCCH last night. The heads are being overnighted to Ed.
On a 4.03" test bore I saw a peak flow of 347@.650" lift. The exhaust ports peaked flow at .700" lift and flowed 244.7cfm without a test pipe. The intake runner is still relatively small in volume compared to the stock runner size. The Stage 2 intake runners are 268cc (stock is 257-260)
I'll post up full flow numbers when I get them.
Ed will have the heads today. I'll see if he can post some pics.
BTW: The dyno numbers were done with 3.90 gears. I'm not sure what the reduction is but it's some.
Old Feb 21, 2007 | 06:30 AM
SideStep's Avatar
Old Feb 21, 2007 | 07:04 AM
edcmat-l1's Avatar
^^^^Glad somebody got a kick out of it.....Intended that way
Old Feb 21, 2007 | 07:11 AM
edcmat-l1's Avatar
We wont be trying 10, but between this and another, we'll probably try 4.
And we have a couple cathedral port ls2 403s we will be trying probably 4 diff ones in.
Old Feb 21, 2007 | 09:04 AM
2c5s's Avatar
Originally Posted by Big-DEN
Tight LSA of 110 and under.
Still alot of work to be done.
As mentioned previously... Iron 408, stock casting L92 heads, REV valves, L76 intake, 36lb. inj, NW90, 11to1, Kooks 1 3/4 LT's w/cats, 3.73, Textralia, LSK 231-235 110+0 in my CTSV
[IMG][/IMG]
Old Feb 21, 2007 | 09:25 AM
SDB's Avatar
SDB
OK totally off track from the rest of this cam stuff....why did the original poster not use the injectors that come with the L76 setup? I thought they were 39 lb.s, pleanty for NA motors under 600 hp. Just curious.
SDB
Old Feb 21, 2007 | 10:03 AM
WKMCD's Avatar
SDB
I run a return style system. I bought the manifold bare and added FAST fuels rails and SVO42's.
Old Feb 21, 2007 | 11:38 AM
Patrick G's Avatar
LS1 Tech Administrator
Off topic, but I love the valve covers and fuel rails.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 21, 2007 | 11:48 AM
1bigcam's Avatar
me too ,were are the coils?
Old Feb 21, 2007 | 11:49 AM
WKMCD's Avatar
Thanks, 2 step powder coat Candy Apple Red. They really show up in light.
Old school!
Old Feb 21, 2007 | 11:50 AM
WKMCD's Avatar
What coils? Phil99vette relocated them behind the inner fenders.
Old Feb 21, 2007 | 12:02 PM
edcmat-l1's Avatar
Originally Posted by WKMCD
What coils? Philc5vette relocated them behind the inner fenders.
Damn, and I thought the plug wires went right to the battery!!lol
Old Feb 21, 2007 | 01:26 PM
Phil99vette's Avatar
7 Second Club
The plug wires go right behind the battery. Looks slick!
Old Feb 21, 2007 | 01:30 PM
  #39
1bigcam's Avatar
is there a kit for that
Old Feb 21, 2007 | 01:35 PM
  #40
WKMCD's Avatar
WCCH Stage 2 flow numbers. Not too shabby.
Ed has a set in his hands and they're going on the car this week.
