L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 02-22-2007, 08:54 PM
  #61
edcmat-l1's Avatar
Originally Posted by BlackHawk T/A
My Fuji can. Look for a button that looks like a flower. It is usually called "Macro" mode. An older model may not have it.
Gotcha. Post # 56...
Will try tomorrow
Old 02-23-2007, 06:39 AM
  #62
texada's Avatar
Originally Posted by Richard@WCCH
Nice pics Kevin. Glad to see they got there ok. They were a mere speeding ticket away for not making it there today. My driver was driving to UPS like a madman last night to get there before they closed and he got pulled over for speeding and failing to use his turn signal. The cop let him go so he could get to the customer counter before they closed. Close one........
Unfortunately we have to deal with a cylinder bore in the way. In my testing with the L92's I see a lot of sensitivity to bore size. I do not have a 4.00" test bore and so won't be able to generate data on that bore size. Sorry for this omission.
GM has moved both of the valves toward the cylinder wall and increased valve shrouding. Coupled with our chamber design (4.125" span) the valve sits up against the top edge of the bore at around the .450" lift area (196cfm at .350" is pretty decent). Once the valve clears the bore edge the flow continues upward in nice strides. Notice the effect is lessened on the larger test bore. I chose to run with the current port design as it produced the highest average flow across the useable lift curve (.200"-.600"). I have some port designs that have really nice low lift flow but fall flat at .500" and up. Likewise I have some designs that flow larger numbers at .650" and .700" but are pretty poor in the lower lift region. I don't feel those ports are good for street use.
Richard
How much are you selling these heads for and do you currently have any available?
Old 02-23-2007, 07:27 AM
  #63
edcmat-l1's Avatar
Did you PM Richard?
Old 02-23-2007, 08:37 AM
  #64
Richard@WCCH's Avatar
Final pricing is still being worked out and I don't have a number yet. We're going to offer the heads with stainless valves and Patriot Extreme springs as part of our Stage 2 package.
At the moment I'm waiting for a shipment of intake valves to arrive. I'm told that should happen within two weeks.
Richard
Old 02-23-2007, 09:17 AM
  #65
WKMCD's Avatar
488/460 so far and still tuning. Much better than I thought this cam would do with stock L92's. Full results and graph shortly.
Old 02-23-2007, 09:31 AM
  #66
2c5s's Avatar
Better! Same dyno? Mine only wanted 25.5' of timing. We tried it up to 30' and it made no difference.
Old 02-23-2007, 09:41 AM
  #67
WKMCD's Avatar
This is cam swap only. The engine was getting pretty hot on the 490 pull. Ed's going to let it cool and do one more run.
It's really interesting. These are VERY different cams and the results are very close across the board. Next will be the head only swap numbers. Now those should be interesting.
Run 7 is the original cam and run 13 is the 234-240 112 +0 cam.
Old 02-23-2007, 09:46 AM
  #68
7 Second Club
Phil99vette's Avatar
And to think you could have gotten a vengenance stock bottom end H & C package and made 30 more RWHP. Like I have always said and you know where I stand on dynos. Who cares what the dyno says, get your A/F right and enjoy the car.
  #69
WKMCD's Avatar
Yes, same dyno and Ed is setup to get the most conservative numbers he can so we don't get into the rock throwing we've seen lately. We were getting KR at anything over 25 before. Ed said he was able to put in a little more timing with this cam. Can't wait to get the CNC'd heads on there with this cam. I'm going the same way you did for a very drivable car even if I give up some on top.
Old 02-23-2007, 09:49 AM
  #70
7 Second Club
Oh, can you have Ed do one pull with:
No belt
Loose Straps
Inflate the tires to 50psi
3.42 rear
Lightweight rims
Swap the clutch out for lightweight unit
Move weather station to heated office or put it in a warm spot and report back.
Old 02-23-2007, 09:53 AM
  #71
2c5s's Avatar
Yes, same dyno and Ed is setup to get the most conservative numbers he cam so we don't get into the rock throwing we've seen lately. We were getting KR at anything over 25 before. Ed said he was able to put in a little more with this cam. Can't wait to get the CNC'd heads on there with this cam. I'm going the same way you did for a very drivable car even if I give up some on top.
I saw the heads, you'll like them!!! Mine are coming off shortly to have Richard run his program through them. While they are off, I have a set of AFR 225's and a FAST 90 left over. They will get bolted on while the L92's are being ported. No other changes, C.R. will be the same. A nice little comparo.
Old 02-23-2007, 09:58 AM
  #72
WKMCD's Avatar
I think the new heads with lower compression/more timing should put us close to 515-520 and about the same gain in RWT. Not bad for a very drivable 402 with a baby cam.
  #73
edcmat-l1's Avatar
No belt
Loose Straps
3.42 rear
Lightweight rims
Dontcha know, thats what we just did.....we put on the saver spares, took off the belt, and ran her in 5th gear.
Old 02-23-2007, 02:22 PM
  #74
LS1TECH Sponsor
Ryne @ CMS's Avatar
i thought bret bauers cams were the almighty camshafts ( well thats what he says), but i guess not....
Old 02-23-2007, 02:48 PM
  #75
Stang's Bane's Avatar
I guess you hit a homerun first rattle out of the box everytime huh??
Changing the cam, lowered the DCR, which allowed more timing, which picked up the power. This was one of the first cams in the country designed for L92 heads, so it was a pretty good effort in my book.
If you will look around, NO-ONE hit it out of the park with these heads the first time around.
But then again he made 380 tq at 2200 rpm, I consider that pretty good.
Old 02-23-2007, 03:38 PM
  #76
WKMCD's Avatar
good.
Thanks for saving me the trouble. That cam was spec'd back in September when Bret and I first started talking. More has been learned since then but you're right 380RWT at 2200 is nuts. The car has been a blast to drive with 3.90's in the back.
Old 02-23-2007, 04:13 PM
  #77
edcmat-l1's Avatar
DING DING DING. Give that man a prize! All kidding aside, thats exactly the case. Its not a secret number grind that makes unreal power.
I agree. And these are REAL WORLD numbers.
Also consider, this cam is a little short on the lift. I would like to have seen another .030 on the lift. We may try another, if permitted.
Old 02-23-2007, 04:23 PM
  #78
speed_demon24's Avatar
Thats funny, I only gained 4mph in the 1/4 with one of his cams that is very similar in size to my old cam.
Old 02-23-2007, 05:18 PM
  #79
dame's Avatar
More has been learned since then .
and WHO was the first to reveal their L92 cam specs ... to help the LS1 community.........
Old 02-23-2007, 07:12 PM
  #80
StingrayCrazy's Avatar
Very respectable numbers! Looking forward to the CNC Dyno results.
Frank
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
