APS charge pipe came off oncesusp loaded
Old Jun 23, 2008 | 10:10 AM
barnat's Avatar
Default APS charge pipe came off oncesusp loaded
Has any of you had the drivers side turbo charge pipe come off once the car was on the ground and loaded? I notice when it was being alighned that it was off of the turbo hose its self! It looks like the front sway bar lifted or pushed up on the pie its self when the susp was loaded!! It almost looks like the only way to fix it, is the pipe its self needs to be bent down right at or aft the front sway bar!! Any thoughts guys????
Old Jun 23, 2008 | 12:50 PM
barnat's Avatar
Default Nobody??
Nobody???
Old Jun 24, 2008 | 09:38 AM
KWIKKAR's Avatar
I don't think you can run a Front sway bar with an APS kit. I had to take mine off as well. Was not to happy when I found this out.
Old Jun 24, 2008 | 09:53 AM
ddnspider's Avatar
wow....did they tell everyone that somewhere or leave it for a surprise?
Old Jun 24, 2008 | 10:08 AM
Superman09's Avatar
LS1Tech Sponsor
I'm running my front sway bar!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 24, 2008 | 10:10 AM
52172's Avatar
I don't have the aps kit, but my crossover pipe was in the way of the front swaybar big time and we had to make spacers that are about 2" tall to lower the swaybar. Works great.
Old Jun 24, 2008 | 10:37 AM
Juiced's Avatar
chances are you need to put in new engine bushings/mounts, the ones you have are sagging and screwing with the placement of the turbos hoses and lines.
Old Jun 24, 2008 | 12:36 PM
TNTramair's Avatar
you can run a sway bar but its built around the stock one. i had to remove my Front Spohn bar aswell cause it wouldnt fit.
Old Jun 24, 2008 | 09:28 PM
barnat's Avatar
This is exactly what i was thinking of doing while i had it up on the lift looking at it tonight LOL SAbout 2 "HUH ???Sounds about right LOL Thanks ,Did you have to do anything with the stab pins ???
Old Jun 25, 2008 | 12:32 PM
ls1greg's Avatar
My front sway bar (35mm from SLP) was banging on the charge pipes at first... I found a few speed bumps and fixed that real quick! There's plenty of clearance now.
Old Jun 25, 2008 | 02:38 PM
barnat's Avatar
No, I put in brand new poly mounts that came with the APS, im thinking its because i lowered the car with a strano kit !!and went with a UMI K member too!!Which i DONT!!Regreat LOL!!
Old Jun 25, 2008 | 02:53 PM
barnat's Avatar
LOL!!!thats some funny **** my man If i could get mine to stay on after i load the susp ???that might be an option LOL!! I ended up buying a spacer/lowering kit for the front sway bar from turbo technologies for $75 shipped and it should take care of my issues with the sway bar pushing up on the charge pipe!!Thanks for all the info guys and this is one of the reasons I love these site and you guys LOL!!!my wife still doesnt get the F Body thing LOL!!Thanks guys!!Ed Barnat
Old Jun 25, 2008 | 03:32 PM
barnat's Avatar
Default Turbo Technology Inc...
Ok guys ,I just got off the horn with Nick over ther at Turbo Technologys and he said he's actually the one that makes these kits and they come in two diffrent sizes which are 1 1/4 and 2" I went with the 2" myself since my car was lowered too. There phone # is 253-475-8319 and cost is $75 shipped threw pay pal.This info is for those of you that are having the same problems as me with my front stab bar hitting and pushing off of the drivers side charge pipe and the rubbing threw on the passanger side pipe!! Good luck guys
Old Jun 26, 2008 | 08:02 AM
Hugger Z's Avatar
Hmmm, stock swaybar on the car with no problems now. But good to know that I might run into this if I lower the car. I was planning to eventually go the Strano route. Thanks for the info Ed!
Old Jun 26, 2008 | 06:38 PM
peter@aps's Avatar
FormerVendor
The F body twin turbo system was designed around the stock F body sway bar and the turbo system fits perfectly with the stock sway bar.
Peter
Old Jun 28, 2008 | 03:23 PM
fil131's Avatar
I am having this problem with the stock sway bar and suspension. any suggestions?
It is pissing me off.
Old Jun 28, 2008 | 03:25 PM
ddnspider's Avatar
wow....peter please explain that?
Old Jun 28, 2008 | 03:32 PM
fil131's Avatar
I've tried, turning the pipes upwards and they just dont clear, I dunno, I was thinking of taking the pipes to an exhaust shop to have them re-bent. Unless you guys can suggest otherwise.
Maybe spacers are the way to go.
Old Jun 28, 2008 | 03:41 PM
fil131's Avatar
What does not having a sway bar do anyway?
Old Jun 28, 2008 | 03:45 PM
ddnspider's Avatar
makes turning much harder.some say its dangerous for a street car but plenty of people run it.
